Considering first engine compartment cleaning
Results 1 to 10 of 14
Thread: Considering first engine compartment cleaning
    Aug 2008
    Central Montana
    30
    I have a 2000 GMC Sierra 1/2 ton with the 5.3L V8. I'm considering cleaning the engine compartment but with all of the various components and stuff it doesn't seem possible to cover up the things that might get damaged. The coils alone are all over the place.
    How should I go about cleaning this particular engine compartment?
    Registered Member Still Learnin's Avatar
    Feb 2009
    Rancho Cucamonga
    405
    15
    Re: Considering first engine compartment cleaning
    Im not going to lie... Ive never really cover anything on an engine unless it was an exposed air filter if i do i use plastic bags and foil. you can wrap foil around anything and make it stay... my approach to engine details are as follows
    1. Mist with water to remove loose dirt (not focusing with a stream in 1 certain spot)
    2. Spray down with an APC
    3. Agitate with a brush
    4. Rinse (not focusing with a stream in 1 certain spot)
    5. Blow dry with compressor
    6. Dress engine
    7. Shut hood and start engine for 5 minutes
    8. Wipe off excess
    Good luck let us know your approach
    - Markito -
    Jul 2010
    La Habra, CA
    3
    I clean my engine compartment when it gets very dusty and I never cover any thing do not use any harsh cleaners as they will attack the wires I
    Aug 2008
    Central Montana
    30
    I appreciate the information.
    My engine has so many wires and things all over it doesn't look possible to scrub or brush anything.
    Looks like spraying with APC and gently rinsing off (i.e. not power spraying) is my best option.
    Thanks...
    Regards...
    Aug 2008
    Central Montana
    30
    This is a picture of my engine and all the stuff thats in the way. The other side is just as covered.
    Registered Member THE BIG BUFFER's Avatar
    Jul 2006
    347
    17
    I wash about 7-9 engines a day. I spray a degreaser and let it dwell for a few minutes. I don't scrub anything. Rince off with pressure washer and apply water based dressing, close the hood and walk away. Always looks awsome (look at my avatar) and I have NEVER had a problem with any electronics.
    Sorry Meg's but none of what I use on the engines is from Meguires. I wish i could use your products for th engines but just too hard to come by.
    Professional Automotive Reconditioning Services
    "You scuff it-I buff it!"
    Registered Member fordf150's Avatar
    Jul 2009
    Hanover Minnesota
    159
    12
    Quote Originally Posted by THE BIG BUFFER View Post
    Have you ever cleaned the newer Ford Triton engines (4.6 or 5.4L modular) with your method and if you have, any issues with electrical components?
    2019 Ford F-150 XLT SPORT 4X4 Ecoboost
    Aug 2008
    Central Montana
    30
    I tried some APC+ on a couple of areas of the motor compartment as a test but the APC+ had no effect on the grime. Looks like I'll have to move up to a degreaser.
    Jan 2014
    honolulu,hawaii
    23
    6
    Some time I use a mixture of dawn and water on spots that APC could not remove. Patience and elbow grease goes a long way in detailing an engine compartment.
    Jan 2014
    honolulu,hawaii
    23
    6
  1. Aluminum corrosion in Engine compartment
    By steve911 in forum Engine Compartment Detailing
    Last Post: Jun 14th, 2009, 01:24 AM
  2. I Love it when the engine looks new! Engine Detail 2008 Fit.
    By MDetail in forum Show Off Your Latest Detail Work
    Last Post: Nov 24th, 2008, 01:54 AM
  3. Replies: 29
    Last Post: Jun 24th, 2006, 11:45 AM
  4. Cleaning my 03 maxima's engine
    By Jason23 in forum Engine Compartment Detailing
    Last Post: May 16th, 2006, 07:26 AM
  5. Cleaning and Detailing Engine
    By kwgardner in forum Engine Compartment Detailing
    Last Post: Aug 23rd, 2005, 08:00 PM
