Just used it today and I like it a lot. First I used a mf mitt and noticed it gets really dirty. But then trying to rinse it out and the mitt is greyish. Is that normal? I then got worried and ended up using a waffle weave towel and the dirt rinsed off easily. Wondering if any of you use waffle weave not only for drying but washing too.
ONR first timer
Re: ONR first timer
Don't worry about whether the dirt rinses completely out of the mitt during an ONR wash, though it helps to rub it against the grit guard in the bucket (if you have a grit guard--if you don't, get one!). Go over each panel at least twice before drying. A waffle weave towel for drying purposes works well. If you see that your drying towel is getting dirty, then that means that you need to wash the panel yet again.Swirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
Re: ONR first timer
The important thing is not to dry the panel until you are confident you have it clean; otherwise you will be grinding grit into the paint. If your ONR bucket gets real dirty, empty it and fill it up with a fresh ONR batch.Swirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
