Single stage paint.
Results 1 to 10 of 12
Thread: Single stage paint.
    Jul 2010
    Georgia
    3
    Single stage paint.
    I have a hardtop, red in color. The paint is somewhat smooth but very faded. I first clay barred it then I tried colorx with minimal results. I later used cleaner wax,deep crystal polish, and finally deep crystal carnauba wax.
    A little better but not the results I expected.
    What else can I try?
    39
    19,196
    237
    Re: Single stage paint.
    Some pics would help most to see what all needs fixed.
    May 2009
    palm beach gardens FL
    305
    15
    Well the products you used are not very aggressive so you can't expect too much correction from them. Go a little more aggressive, something like UC and see how you like it. You need to get that "very faded" layer of paint off.
    Jul 2010
    Georgia
    3
    I cannot get pictures right now but will later today. I am going to try UC. Will the ultimate compound remove the wax I applied earlier or should I wash the top again? Also, what should I use to apply uc?
    39
    19,196
    237
    I like using the smooth foam applicators for most products.
    And yes, it will remove your wax. You do want to work on a clean surface though, so either wash it, or if it is just a little dusty, you can use the QD spray and a good towel.
    Registered Member sleepy's Avatar
    Mar 2009
    meadville, missouri
    628
    127
    Without seeing what you are talking about, I would say that using UC on your SS paint might be a little to harsh. Try M80 first, then step up to UC if not satisfied. M80 is made for SS paint like what you and I have, plus it has polishing oils that UC does not have.
    Sleepy
    Love the Classics!
    Apr 2008
    Bradford, UK
    167
    14
    #80 ... maybe get up to #83 to strip out the fading/oxidisation. These old-fashioned polishes are chock full of oils that massage into single stage paint - if you have single stage paint, you HAVE to have #80 and #7 as a bare minimum.
    Are you working by hand or machine? By hand, #83 can be used, but use a LOT of effort to work it all the way through. #80 can be used by hand. By machine, both are very effective.
    I also mentioned #7 - this is for hand use only and is quite unique among polishes/glazes. It's a little like Deep Crystal Polish but more so. Essential kit for single stage.
    Follow on with a nice wax - I'd suggest #26 (liquid or paste) or 3M Show Car Paste Wax.
    21,402
    1138
    Quote Originally Posted by sleepy View Post
    Quote Originally Posted by Orca View Post
    We tend to lean toward the above posts as the approach we would start with on this single stage painted hard top for your Miata. The comments stated above outline the reasoning perfectly and we highly recommend this approach.
    Sep 2005
    14,251
    537
    Did you use the products in the order stated?
    I would have used the polish before the cleaner wax.
    21,402
    1138
    Quote Originally Posted by J. A. Michaels View Post
    The order he listed the products in would have been correct - "cleaner wax,deep crystal polish, and finally deep crystal carnauba wax" - because he was going for the cleaning first, then polish, then wax. The cleaner wax would have removed at least a good portion, if not all, of the polish.
    His product order was correct, for the products at hand. The problem is that Cleaner Wax simply doesn't have the defect correction ability he needs for this project. M80 would be far superior in this regard.
  1. Single Stage paint problem
    By The Wonder Wagon in forum Working by Hand
    Last Post: Jun 11th, 2010, 08:49 AM
  2. What is a Single Stage Paint?
    By mis3 in forum Detailing 101
    Last Post: May 27th, 2010, 11:49 AM
  3. whats the difference
    By bjayjr5679 in forum Detailing 101
    Last Post: May 22nd, 2006, 06:27 PM
  4. Claying im stuck ??
    By WhiteCamaro88 in forum Detailing 101
    Last Post: Jun 21st, 2005, 02:03 PM
