The Challenge of Delicate Paint - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 65
Thread: The Challenge of Delicate Paint
  1. #41
    Nov 2011
    usa
    4
    9
    Re: The Challenge of Delicate Paint
    Great info, i had to work on a Subaru Legacy a while back, it was one of the softest paints i worked on, i had a hard time working with it because after getting excelent correction i would make scratches with my microfibers. it was a nightmare!
    then on the other side of the scale i have been hit with audi paint (really hard to correct on some cars) where 105 and megs cutting pad (g-220) wasn't making a dent in the swirls
  2. #42
    Nov 2011
    Jakarta, Indonesia
    19
    9
    Can I use D151 for delicate paint with rotary? (Pad : Meguiar's Polishing W8...)
  3. #43
    21,402
    1138
    Quote Originally Posted by Rafael Rakyan View Post
    Yes, you certainly can. But if the paint is really delicate you may struggle to finish hologram free with a polishing pad on a rotary. D151 may do a very good job of concealing rotary swirls due to the wax protection it leaves behind. That does NOT mean it's just a filler product, don't get us wrong. It does an outstanding job of actual defect removal, but what's left behind can conceal to a degree. And that could hide buffer swirls on very delicate paint.
  4. #44
    Registered Member zbestwun2001's Avatar
    Aug 2011
    Encino, Ca.
    151
    According to my body shop I have delicate paint. It is a single stage, not real expensive paint job. I had it done end of last May and it still really does look good. Even, the body shop ( who are friends) said that shop did a good job. It is also not very thick, in fact it's thin.
    Using UQD, and NXT 2.0 and UQW. These three products have kept the paint very healthy and when I run my hand across it it is very glass like. A few little bumps but that's the paint job.
    I am VERY leery to use just about anything else on it. I really don't have swirls, I might have a couple MF scratches but the car is Metallic Beige and they don't show.
    BUT, is there anything that Maguiar's makes that will make it look even better safely?
    I wax by hand using a hand held applicator.
    I have a tendency sometimes to "if it's not broke, fix it till it is", if you know what I mean. I don't want to do that here, it looks to good. If I went to sold it I could get top dollar for it as it also only has 111K mi. on it. It's very clean inside and out.
    Do you think I should just stay on this same routine, it seems to be working great?
    Thanks
  5. #45
    39
    19,127
    237
    It would be good to try out the Cleaner/Wax, or ColorX as a step before the wax.
    If leery, you would just do a panel or small area at first, and inspect it. Then move on.
  6. #46
    Aug 2011
    Encino, Ca.
    151
    Being that I know I am dealing with a thin coat of paint, does this remove any of the paint?
    Thanks Mat
  7. #47
    39
    19,127
    237
    No, they are both quite mild used by hand. You can work them in a lot of course, but you can also apply them by just wiping around like a regular wax, just to get a little dirt cleaning.
  8. #48
    Aug 2011
    Encino, Ca.
    151
    Thanks
  9. #49
    Nov 2011
    Jakarta, Indonesia
    19
    9
    To prevent any scratches/swirls on delicate paint, better if I use D151 by hand or rotary? Thanks
  10. #50
    Sep 2005
    Sydney, Australia
    4,290
    64
    As stated by Michael above, it may be difficult to finish hologram-free with D151 via rotary on delicate paint. So if that's what you want to prevent, do it by hand.
    Either that, or be prepared to do a second step with a less agressive product on the rotary.
  1. Wet-sanding - Fresh Paint vs Factory Paint
    By Mike Phillips in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 15th, 2011, 06:39 AM
  2. best buffing compound for my needs
    By dbthump in forum Sanding Automotive Paint - Hand/Machine
    Last Post: May 31st, 2006, 06:04 AM
  3. Breaking Down Glaze
    By JSUPER in forum Detailing 101
    Last Post: May 30th, 2006, 04:16 PM
  4. whats the difference
    By bjayjr5679 in forum Detailing 101
    Last Post: May 22nd, 2006, 06:27 PM
  5. Claying im stuck ??
    By WhiteCamaro88 in forum Detailing 101
    Last Post: Jun 21st, 2005, 02:03 PM
