I have been working on trying to remove some water etchings that recently got on the hood of my car, and have previously tried another finishing polish with no luck. It looked perfect after using the previous polish with my Porter Cable 7424 and Lake Country pad, but the next day after having the car in the sun and heat the marks reappeared. I am guessing the heat evaporated the oils and exposed these etchings again, since the surface did feel slick after polishing.
Desperate for something that will work, I bought a bottle of both M105 and M205. The other day I decided to test out the 205 on a small area by hand using a foam applicator just to see what it could do. The finish is perfect outside of these marks, so I figured I'd try the lesser of the agressive products first. I made 6 or so passes using light pressure, and then wiped off the area with a microfiber. I was kind of shocked, becuase 90% of the water marks were gone, and the 205 did not really feel like much of an abrasive polish. I left the area untouched without an other futher polishes or waxes after using the 205 just to see if these marks will reappear, and they didn't after the car sat all day in high 90 degree weather. I probably should do an isopropyl alcohol wipedown just to be sure though.
My question is, does 205 have a lot polishing oils in it that could possibly hide defects? Since the bottle says that it is paintable safe, and that finish did not feel slick at all after using M205, it seems like there should not be any in it. I just wanted to find out directly from the source for sure. If I can get by using the M205 I will go that route, I just don't want to end up dissapointed and frustrated again and have them reappear after taking the time doing the whole thing
