I have another post in an auto body forum where I'm doing a spot repair as an amateur. I know my methods aren't approved, but essentially I wound up repainting a spot the size of a quarter with single stage paint on top of my bc/cc paint. I purposely used masking tape with a hole the size of a quarter around the spot, so I have hard masking lines on the edge of the circle.
I have some Meguair's 3000 grit sandpaper on order, otherwise, I have some 3m 2000 grit here presently. I could wet sand the hard edge on the circumference with a sandpaper dot glued to the eraser of a pencil, or I could use a motor guard soft block foam sanding block and cut it to say a one inch square (or should I go larger?) and use that to wrap sand paper around to wet sand the whole spot, hoping it will take down the edge while I sand the whole thing. I know I'm not supposed to paint this way, but I have my reasons.
Instead of the sandpaper, I could use some polish/compound in a terry towel (which would make it aggressive) and lap the edge of the circle instead, but that would probably cause some uneven surface, or worse sand into the circle unevenly.
So ideas on the sanding would be welcome. After sanding, I intend on using some Meguairs fine cut polish or maybe medium cut polish on a porter cable buffer, then follow with Mirror Glaze hand glaze.
