From time to time this comes up as a method for drying a vehicles finish after washing and rinsing. A leaf blower is an ideal way to harmlessly remove droplets of water that can cause water spots once they evaporate. Using air instead of towels makes allot of sense because the only thing that touches the finish is air so it leaves no marks.
I was in the market for one and didn't want to spend allot of money so after looking around at physical sizes, air speed, CFM, and cost I settled on the Troy-Bilt TB197BV Electric Motor Leaf Blower.
This leaf blower is light weight and very maneuverable allowing the user to position it in any way they need it. The airflow is variable but at full throttle this unit makes short work of any water droplets it comes in contact with. The mouths shape of the extension precisely concentrates the flow of clean high-speed air right where you need it making short work of any water leftover after rinsing. The handles are cushioned and the air speed control it variable so the user can adjust it to suit their specific needs.
Engine/Motor - 12 amp Air Speed - Adjustable Air Velocity - 245 mph maximum Air Volume - 475 CFM Construction - Plastic Warranty - 2 years | |
At $59.00 I figured it would be a decent investment for this purpose and I can tell you it was. | |
