Working paint cleaners and polishes
Results 1 to 4 of 4
Thread: Working paint cleaners and polishes
    EPHIOS EPHIOS's Avatar
    Jul 2008
    Las Vegas, Nevada
    800
    19
    Using G110v2 to work paint cleaners and polishes, how do you that you worked them "enough" that there are not benefits of working any farther? Does anyone have an pictures of what it looks like? Thanks!
    Feb 2010
    Suffern, NY
    27
    2,841
    52
    Re: Working paint cleaners and polishes
    It depends on the paint cleaners yo are talking about.
    If you are using DAT cleaners or cleaner/polishes (M85, M84, M83, M82, M80, M09) then you need to work the product until there is only a light film on the surface. Once you see this then you know you have worked the abrsavies completely and the product has been used to it's fullest.
    If you are using SMAT cleaners or cleaner/polishes (M105, M205, Ultimate Compound, Swirlx, ScratchX 2.0) then you can work the product as long as you need to BEFORE the product dries out. This means you can work the product for 5 seconds or 5 minutes if the product does not dry out. M205 for example can be worked for extended periods of time without an issue. On a 90 degree (Farenheit day, in the sun, I made 8-10 passes on a section with M205 and I could have worked it longer. This product has an insanely long buffinh cycle. The good thing is that I could vary the time I spent on each section according to need. If one section needed more time because the swirls were a little more stubborn then I went ahead and buffed longer. If one section only needed a pass or two then that's all I gave it. There is much more user control with the SMAT products versus the DAT products. In general, work a SMAT product for as long as you need to BEFORE it dries. You never want to dry buff and that is the same for DAT products.
    Loves to Detail TH0001's Avatar
    Feb 2006
    Orlando Florida
    38
    1,091
    132
    Quote Originally Posted by EPHIOS View Post
    Hope this helps.
    Jul 2008
    Las Vegas, Nevada
    800
    19
    Thanks, guys! I will be using SwirlX (SMAT) & M07. With SwirlX, I can work it before it dries out. With M07, I can work it until it gets translucent.
  1. Old article from 1994
    By alkemyst in forum The Break Room
    Last Post: Mar 18th, 2008, 03:01 PM
  2. Replies: 42
    Last Post: Jul 22nd, 2006, 08:23 PM
  3. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
