I’m working on repair of a paint chip on one of my Harleys. It’s irregular in shape but about 1/8 inch in diameter. I have the official Harley touch paint kit…. two small bottles -- Vivid Black and clear coat.
I have pretty much followed the procedure outlined by David Bynon ( a touch-up "guru"). http://guidetodetailing.com/damage-r...repair-clinic/ (Scroll down.)
So far I have carefully layered a four coats of black into the chip using a modeler’s detail brush (darn small). The paint, which I have applied, is still below the surface of the paint surrounding the chip.
I had this fender bead blasted and repainted several years ago. I know that the painter used a “ton” of clear coat.
David Bynon suggests not using clear coat for the final layers of the touch-up while most folks using clear. http://www.paintscratch.com/brush.htm
I have been doing touch-ups for lots of years (Would you believe 50!) and have never used clear for the final coats. By the way, I am really quite good at it.
I am striving for perfection on this touch-up. Any suggestions?
Tom
Tom
