MYTEE SPYDER HP60 HEATED EXTRACTOR
Full-sized power in the Spyder's compact size makes it the perfect extractor for the mobile detailer; with the same features and specs of a full size unit the Spyder's only difference is the HP60's 6 gallon tank verse the HP100's 11 gallon tank.
* 100 PSI pump * Powerful 3 stage vacuum motor * 1200 watt in-line heater * Compact design
SPECS
Cords: Single 25' * Body: Roto-molded Polyethylene in YELLOW/GRAY * Tank: 6 Gallon
Vacuum: 1-3 St HP * CFM: 100 * H20: 137"
Pump: Diaphragm * PSI: 120 * GPM: 0.6
Heater: 1200 W.- 210 Degree Maximum
Casters: 3" * Dimensions: 29" x 18" x 37" * Weight: 90 lbs.
Tools: 3" Stainless Steel Upholstery Tool with 15' high pressure vacuum and solution hose
$1100/or best
I have additional tools that work with this unit. I'm selling them separately:
**Minuteman Scrub Wand 14: $200
**Minuteman Motorized Extraction Tool: $200
Or as a lot for $1400.
SPECS
$1100/or best
