D/A Buffing 101 - An Introduction to the G110v2 (and similar) - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 63
Thread: D/A Buffing 101 - An Introduction to the G110v2 (and similar)
  1. #11
    Registered Member Batmobile's Avatar
    Mar 2009
    Indonesia Jakarta
    33
    68
    Re: D/A Buffing 101 – An Introduction to the G110v2 (and similar)
    Great Information!! Thank you for sharing.. How about Rotary? I can't wait to see it too....
    "Does it come in black?" Bruce Wayne / Batman Begins
  2. #12
    BMW Nut smack's Avatar
    May 2010
    Belleville Ill
    963
    19
    Wow Mike! What an informative write up. I will have to re read it when I have more time.
  3. #13
    EPHIOS EPHIOS's Avatar
    Jul 2008
    Las Vegas, Nevada
    800
    20
    So, Michael, is it OK to use masking tape (beige-colored) on taping up the trims and emblems? I am trying the paint's tape, and it is not just sticking for me. Thanks!
  4. #14
    Registered Member Kevin Brown's Avatar
    Apr 2004
    692
    457
    EPIC write-up, my man.
    A 2010 version of information from the past, with some much needed new information for all MOL Members to ponder.
    Another fantastic write-up...
    Brought to us by the man known in the inner circle simply as "STOoooOPS!!"
    Killer work.
    Kevin Brown
  5. #15
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    61
    Awesome writeup, Mike! Already bookmarked this thread as a definitive reference source. Having seen your PT up close at past TNOG's, your finish is everything my Accord aspires to be.
  6. #16
    Why so serious? Big Ed5150's Avatar
    Jul 2010
    Bella Vista, Ar
    47
    16
    Great write up...i think mike did this cause he knew i just bought a g110v2..lol.
  7. #17
    MA
    122
    Awesome write up Mike! Just bought my PC and used it for the first time yesterday. Certainly have a lot of learning/practice to do with this thing!
  8. #18
    21,402
    1138
    Quote Originally Posted by Peter_Klim View Post
    Is there a thread somewhere that steps you through all the necessary stages of washing/correcting/waxing? I'm not talking about full detail, but something that tells you the order of doing it and what products can be used for each step and the strength of the products listed in order.
    That would be our 5 Step Paint Care Cycle.
    Quote Originally Posted by Batmobile View Post
    Maybe in time, but that's not as easy to do via just images and words. There is a whole lot more going on with a rotary compared to a D/A, and much more potential for damage in the hands of a novice.
    Quote Originally Posted by EPHIOS View Post
    The tape used here is Meguiar's Professional Masking Tape rather than typical blue painter's tape. We developed this tape specifically for detailing - it's less expensive than the painter's tape and holds onto trim better due to the adhesive being a bit more tenacious. Painter's tape was developed with very specific painting requirements in mind - light adhesion so as not to damage fresh paint, ability to leave a very clean paint edge line, etc - that are sort of overkill when used for detailing.
    Quote Originally Posted by Big Ed5150 View Post
    Just for you Big Ed, but thanks for letting others read it too!!!
  9. #19
    Registered Member Bill Davidson's Avatar
    Apr 2010
    Edmonton, Alberta, Canada
    1,166
    23
    Excellent write-up Mike. You were able to articulate in writing, what is often difficult to get across even with video. This article should ship as instructions with the G110v2.
  10. #20
    59
    24,767
    519
    Excellent write-up Mike, this is going to help a lot of people new to machine polishing into the future...
    If you don't mind, I would like to add a link to a similar article that brings up the most common problems and then the solutions as it relates to DA Polishers... it might help people to take what you've laid out and if needed tweak their technique and master the DA Polisher...
    Tips & Techniques for using the G110v2, G110, G100, G220 and the PC Dual Action Polisher
    (These are all similar tools)
    After teaching hundreds of classes here at Meguiar's, there are some common mistakes most people make when trying to remove swirls and scratches with a dual action polisher. Most of them have to do with technique.
    Here's a list of the most common problems
    1. Trying to work too large of an area at one time.
    2. Move the polisher too fast over the surface.
    3. Too low of speed setting for removing swirls.
    4. Too little pressure on the head of the unit.
    5. Too much pressure on the head of the unit so the pad quits rotating.
    6. Not keeping the pad flat while working your product.
    7. Too much product, too little product.
    8. Not cleaning the pad often enough.
    Here's a list of the solutions in matching order,
    1. Shrink your work area down, the harder the paint the smaller the area you can work. The average area should be and average of about 16" by 16" up to 20" by 20" or so. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot.
    2. For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's really easy to move the polisher too quickly because the sound of the motor spinning fast has a psychological effect to for some reason want to make people move the polisher fast. Also the way most people think is that, "If I move the polisher quickly, I'll get done faster", but it doesn't work that way.
    3. When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting, again... this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad rotating over the paint as well as the combination of time, (slow arm speed), together with the diminishing abrasives, the foam type, and the pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches. It's a leveling process that's somewhat difficult because the tool is safe/gentle while in most cases, modern clear coat paints are harder than traditional single stage paints and this makes them hard to work on. This is also why people get frustrated, they don't understand paint technology, all they know is their paint swirls easy and getting the swirls out is difficult and thus frustrating.
    4. For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much pressure and the result of too little pressure is no paint is removed thus no swirls are removed.
    5. Just the opposite of item #4, people think that by pushing harder on the polisher they can work faster and be more aggressive, but the truth is the clutch in the tool is a safety mechanism to prevent burning and will cause the pad to stop rotating, thus less cleaning or abrading action and once in a while this will lead a person to then post on the forum something like this, "Hey my pad doesn't rotate". There needs to be a balance of enough pressure to remove defects and keep the pad rotating but yet not too much pressure as to stop the rotating action. This balance is affected by a lot of things, things like type of chemical, some chemicals provide more lubrication and the pad will spin easier, curved surfaces or any raise in body lines will tend to stop the pad from rotating. This is where experience on how to address these areas comes into play or you do the best you can and move on. It's not a perfect tool, nor a perfect system, but it's almost always better than working/cleaning by hand.
    6. Applying pressure in such a way as to put too much pressure to one side of the pad will cause it to stop rotating and thus decrease cleaning ability.
    7. Too much product over lubricates the surface and this won't allow the diminishing abrasives to do their job plus it will increase the potential for messy splatter as well as cause pad saturation. Too little product will keep the pad from rotating due to no lubrication and there won't be enough diminishing abrasives to do any work. Again it's a balance that comes with experience, or another way of saying this would be it's a balance that comes with hours of buffing out a car to learn what to do and what not to do. Information like what you're reading here is just an edge to decrease your learning curve. Hope this is helping.
    8. Most people don't clean their pad often enough and most of the time the reason for this is because they don't know they're supposed to clean their pad often and they don't know how to clean their pad. Again, that's why this forum is here to help you with both of these things. You should clean your pad after every application of product or every other application of product, your choice, most of the time cleaning your pad after every other application of product works pretty well. It enables you to work clean and enables the foam pad, the polisher and the next application of fresh product too all work effectively. How to clean your pad will be addressed below sooner versus later, but not at the time of this posting. (Sorry, I'm behind a keyboard, not a video camera
    The first 4 are the most common.
  1. G110v2 vs PC 7424XP
    By ShineOCD in forum Detailing 101
    Last Post: Sep 6th, 2010, 06:06 PM
  2. Porter Cable or G110?
    By FastFish71 in forum Machines - The Dual Action Polisher
    Last Post: Apr 21st, 2010, 05:08 PM
