Hey i see they have a tip to use a pad prep spray to use before using the pads on the polisher, what can i use if i don't have some of this prep spray they talk about.
Pad prep
Re: Pad prep
When using a rotary buffer it is very common to give a quick spritz of something like M34 Final Inspection prior to putting the pad on the paint for the first time. If you're using a D/A buffer this isn't as critical and the vast majority of D/A users never do it.
But if you're rotary buffing and want to do this with something other than M34, then a little Quik Detailer or Last Touch will do.Michael Stoops
