The Cure for M105's short working time and dusting issues
Results 1 to 10 of 14
Thread: The Cure for M105's short working time and dusting issues
    Registered Member Lasthope05's Avatar
    Oct 2008
    Philadelphia, PA
    191
    12
    As you all know M105 is an a staple in many peoples arsenal. It has the ability to quickly remove heavy defects while finishing up almost LSP ready, but it also has its draw backs. First off , M105 has an extremely short working time and if you over work the product, the residue dries on like cement. Secondly M105 dusts like crazy.
    With M105, many people use the KBM method of pad priming and using a mist of water to reactive/relubricate the polish once it has been worked. Originally using a mist of water was only for the rotary version of the KBM but it shifted to the DA version. I dont know about anybody else but on a DA the M105+water has never worked out too well for me but on the rotary it was perfect.
    The solution/alternative I've found that works better than water as a lubricate is mineral oil(marked as baby oil in the US.) I first found out about this trick when I ran into a G37 with the notorious stick clear coat. No matter what I used or did the polishes I used would gum up on me. I eventually did finished up the car and afterwards searched the forums for a solution to this as I knew I could run into this issue again in the future. In doing so I found out about using mineral oil as a spray lubricate. So, naturally when the car returned for a follow up maintenance wash took out came the buffer for a little testing. Could you have guessed it? It worked like a charm. Working time of M105 went from a few seconds to minutes. The lubrication was amazing and to top it off I noticed a dramatic reduction in dusting.
    The use if mineral oil as a lubricate is not a new concept. I have found that Gloss-it has a product call EVP Prime which is a lubricating oil itself. Now I know people are wondering is there any down side of using mineral oil with M105 or is it compatible with foam pads and after some research I can it is perfectly safe.
    According to the MSDS sheets on M105 avaible on the Meguiars website (LINK.) One of the ingredients used in M105 is Hydrotreated Distillate( CAS number 64742-46-7). Through further research I found Hydrotreated Distillate, specifically CAS 64742-46-7, is closely related and very similar as mineral oil.
    Ok, since I got that covered I'll get into how it is used. First I found that using a small travel sized misting bottle to work extremely well. VS applying a small drop on the pad, the sprayer would evenly coat the entire pad.
    -With a fresh pad, use to sprays of mineral oil to prime the pad for use.
    -Apply a circle of product to the face of the pad and spread it out on the paint. (With the mineral oil on the pad, you no longer have to worry about drying out the compound.)
    -Work M105 into the paint until the defects are removed as usual. (You will immediately notice the added lubricity/working time, very minimal/no dust, and very easily removed residue. This is counted as one cycle.)
    -Clean the face of the pad with a brush to removed spent polish/abraded paint and use a cotton towel to remove the remanding residue in the pad(Cleaning your pad on-the-fly.)
    -Reapply an addition mist of mineral oil after 3 or 4 cycles or each new panel.
    A quick mineral spirits wipedown will show that the defects are removed and not masked by the mineral oil.
    Note: Do not use too much mineral oil as it can over lubricate the surface and cause the pad to essentially "hydroplane."
    I have found after using this trick that I no longer need to use the KBM method with the DA(M105 only.) The (much) longer buffing cycle allows you to really work down those heavy defects but I guess it wouldn't hurt if you do use Kevin Brown Method.
    I also made a little video demonstrating its lubricating/low dusting effect. This is an extreme case video showing how long you can easily work M105 using mineral oil as a lubricant(easily 16-17 passes.) Using a fresh orange pad I primed it with 2 sprays and a circle of M105. Notice at the end how easily the residue is buffed away.
    Click the picture to play the video.
    Alan T.
    Registered Member DgenerationX's Avatar
    May 2010
    Mont St-Hilaire Quebec Canada
    27
    67
    9
    Re: The Cure for M105's short working time and dusting issues
    Very intresting, does priming the pad with oil reduce the abrasive side of M105 at all?? I'm just wondering because if it does reduce the effecacity of M105, would using UC solve the problem of dusting and working time? I'm gonna try it for sure next time I'll work with M105!! Thanks for the info!
    Btw the video didn't work for me, error number 2048
    Sep 2005
    14,242
    535
    Very interesting. I wish I heard of this for a Escalade I did a few months back. I will have to try it. Thanks for the tip.
    May 2010
    27
    67
    9
    Edit : the video works now that i'm home. Just with the first couple of pass, you see that it's alot more easy to work with!
    Head Wax Monkey Black1's Avatar
    Oct 2010
    St. Joseph, MI
    102
    9
    Great tip, Alan... Thanks!
    -Jake
    Better is a poor man who walks in his integrity than a rich man who is crooked in his ways. -Proverbs 28:6
    Jul 2010
    Dallas, TX
    87
    9
    Good work lasthope05. If a couple of spritz's of mineral oil/baby oil works for M105, then I think it would work the same way with D151. I have a problem with it dusting in a short amount of time.
    I hope some of the full time detailers give it a try this week and report in.
    I have a nasty car to do this coming weekend and want to know for myself.
    Again, good work.
    Sep 2005
    Sydney, Australia
    4,280
    63
    Thanks for sharing the tip!
    Wouldn't the mineral oil somwhat reduce the abrasiveness of M105? I'd think it would have to.
    MA
    122
    Registered Member Fly Bye's Avatar
    Nov 2009
    Nor Cal
    52
    731
    16
    It might, depending on how much was used. If you were nearing the end of the buff cycle, would it matter
    Detailing Dunce akimel's Avatar
    May 2008
    Roanoke, Virginia
    2,378
    148
    --Al Kimel
