Extremely Stubborn Water Stains
Results 1 to 10 of 16
Thread: Extremely Stubborn Water Stains
    Oct 2010
    Texas
    4
    12
    Ok, I got some water stains and I cannot get rid of them! Tried good Car wash 3x, using Meguiar's Soap, then tried Meguiarls Swirl removal, also tried a bit of Vinegar, and now I will try Meguiar Scratch Remover 2.0. But if it does not get removed with the Meguiar Scratch Remover 2.0, would it be any harm if I leave it just as is for few months? I am going to save money to buy all the equiptment to buff it and polish it my self......but man, one year old car, **** load of water stains.....dam apartment sprinklers.....
    41
    19,277
    240
    Re: Extremely Stubborn Water Stains
    Well, with good washing, you should have removed the worst of it, that would keep etching in.
    As far as removing.... hard water can take some effort. Even wax is just a few molecules thick, something strong can get past it.
    To remove swirls, spots, etc, the products do need worked in some. A common mistake is to wipe them on and remove like a polish or wax.
    Sep 2005
    14,253
    539
    If they are type 2 water spots that would require more effort. They are stubborn as you well know. I personally would get after them as soon as possible. It is always easier to maintain, then to let them build up for a couple of more months, then try to remove them all.
    Rally / Off-Road Nerd AWD_Junkie's Avatar
    Nov 2010
    Nashville Tennessee
    40
    6
    12
    Sounds like a case of extremly hard water. I had an '06 WRX recently and I washed it for the first time at my house and it looked like I had given it a limestone bath. Took it to a friends house a town or so over washed it there a few times, waxed it real good and no more spotting. I've since installed a water softining system on the house. and no more spots.
    Registered Member ShinyChevy's Avatar
    Feb 2008
    64
    14
    Yep, water spots can be a hassle. Here in Houston the tap water can get up over 270 ppm TDS and leave spots which are difficult to remove. I've had some mild ones which came off with a claybar and some very tough ones that took #105/cutting pad/rotary to remove. Hopefully yours will be the easier ones!
    If you don't have the time or equipment to tackle the spots right away, it does make sense to keep up your regular wash & wax program. While it probably won't do a lot to remove existing spots, it certainly can't hurt and a good wax job will help prevent new calcium deposits from sticking.
    Good luck and let us know how it comes out
    I saw it on the Internet...it must be true!
    May 2011
    NLV, NV
    5
    So I have the same problem, I have used vinegar, clay, swirl remover, although today i will try with buffer, is there any other way to get rid of them. When I was before the clay, should i do with like dawn to get all the wax off?
    Jun 2009
    Reunion Island
    18
    prevent : wipe with QuickDétail , Last touch , ONR
    remove : paint cleaner ( less to most ...)
    DC1 to UC or 105
    try aquagleam filter or something like it .
    21,405
    1141
    We've seen extreme cases of water spotting caused by reclaimed water used in apartment complex sprinkler systems. When this gets really bad, even rotary buffing with a wool pad and M105 can be challenged. Washing, vinegar, clay, a light paint cleaner by hand - none of these will touch the very worst water spots, unfortunately.
    In absolute worst case scenarios we've seen wet sanding as about the only remedy. The problem with these severe water spots is not that there's something left behind that won't let go, but rather the fact that they are deeply etched into the surface of the paint, so you need to level the paint to remove them. And the worse the water spots, the more aggressive you need to go in order to correct them.
    Thankfully, most of the time they aren't so severe and a little Ultimate Compound via DA takes them out quickly.
    Oct 2006
    19
    16
    I know this thread is old but I'm dealing with the exact same issue right now. I have a white Tundra Crewmax that is riddled with water stains (assuming that's what they are. I have a DA but can't apply enough pressure and still keep it spinning so I had to resort to hand application with a MF pad. The Ultimate Compound is doing the trick but it probably takes me at least an hour for a fender or door. The hood took me about 3 hours to prep for NXT. I'll try posting some before and after
    Before shots (you can see where I've done and where I haven't)
    Oct 2006
    19
    16
    And after the fender was completely done
  1. Hard Water Stains and Spotting
    By malageno in forum Detailing 101
    Last Post: Apr 5th, 2010, 07:57 AM
  2. Re: Some conversation between Kevin Brown and Barry Theal
    By Kevin Brown in forum Machines - The Dual Action Polisher
    Last Post: Jan 23rd, 2010, 09:55 AM
  3. Stubborn Water Spots
    By FTStang08 in forum Detailing 101
    Last Post: May 31st, 2009, 03:19 PM
  4. Replies: 5
    Last Post: May 8th, 2008, 08:46 AM
  5. Gold Glass residue
    By KLnyc in forum Detailing 101
    Last Post: Jul 12th, 2005, 04:38 AM
