I'm attempting to help a sibling with a bad gouge he has on his car. I'm planning on spraying it down with some new paint, then wetsanding that down and polishing it.
I've had bad luck with wetsanding in the past. I believe it was due to me using wetsand paper that you find at walmart, target, etc, and it kept leaving all sorts of tracers behind after buffing it, even with 2500 grit paper.
So, I decided to make the leap to meguiar's sanding blocks as I've heard they're just better. Unfortunately, they're a bit pricey at about $15-17 per block. I decided to just purchase the 1000 grit and 2000 grit blocks as a 3000 grit one was $33
Now, my question is this.. is 2000 grit fine enough to remove the marks with M105 and a DA polisher? I don't have access to a rotary and don't plan on attempting to use one at this point in time.
Thanks for any help!
