Degreaser stained paint - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Degreaser stained paint
  1. #11
    Jun 2005
    The Real NorCal
    4,116
    144
    Re: Degreaser stained paint
    Did you dilute the Simple Green? The best way to prevent staining is to soak the panel in the soapy wash solution instead of just hosing the panel down.
  2. #12
    elbow greaser Spidey's Avatar
    Vancouver Canada
    113
    Quote Originally Posted by roushstage2 View Post
    i didnt dilute it.. it was the max strength one too lol... i sprayed down the fenders and the whole car with water but not soapy water.. in the future i am going to mask and bag the fenders
  3. #13
    Jun 2005
    The Real NorCal
    4,116
    144
    Quote Originally Posted by Spidey View Post
    i didnt dilute it
    The number 1 cause of problems with most products...not following the directions. Soapy water works fine. I've never stained any paint with Super Degreaser.
  4. #14
    Vancouver Canada
    113
    ya i take full responsibility.. i just assumed since it was already in a spray bottle, it was ok.
  5. #15
    21,402
    1138
    A great way to mask off fenders and the front end of a car before spraying any cleaner/degreaser in the engine bay is to split open some large plastic garbage bags and use masking tape to anchor them to the inside edge of the fender with the hood open. Mask all around the engine bay like this, even securing the bottom of the plastic to the side of the car with a bit of masking tape - even a gentle breeze will blow that thin plastic around. 3 or 4 large garbage bags is all it takes to mask off everything.
  6. #16
    Vancouver Canada
    113
    thats what i had in mind
    btw simple green doesnt say to dilute when using with automotives
  7. #17
    Jun 2005
    The Real NorCal
    4,116
    144
    Perhaps the Max Stuff is different? Regular S.G. needs to be diluted, at minimum, 1:1. We live and learn. I found out the hard way once as well, lol
  8. #18
    Feb 2011
    St. George Utah
    110
    A little older thread here--but did you ever find a solution?
    If not, how about fighting fire with fire? Alot of caustic based degreasers (not sure if krud kutter is) will need to be reactivated if left to dry. Using a little more and then rinsing very well while still wet may get a better base to start with.
    Brandon
    Custom Cleaning Concepts, LLC
    (435) 249-4CCC (4222)
    "When you want your ride as clean as can be, you need to call CCC!"
  1. D/A Buffing 101 - An Introduction to the G110v2 (and similar)
    By Michael Stoops in forum How To Articles
    Last Post: Jan 3rd, 2018, 11:37 PM
  2. Wet-sanding - Fresh Paint vs Factory Paint
    By Mike Phillips in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 15th, 2011, 06:39 AM
  3. Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant
    Last Post: Sep 9th, 2010, 06:25 PM
  4. What is the meaning of soft paint?
    Last Post: Jan 23rd, 2009, 10:23 PM
  5. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
