How to apply a very thin coat of wax with a G110v2
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: How to apply a very thin coat of wax with a G110v2
    21,405
    1140
    How to apply a very thin coat of wax with a Dual Action Polisher
    This write up originally appeared in a thread about the Thursday Night Open Garage session where this experiment took place. But not everyone reads the TNOG Images threads so we're duplicating this in the How-To section for better exposure.
    Prompted by a couple of discussions recently about application of a very thin layer of wax, and talk about the amount of product actually used, we thought we'd prove that you can indeed wax a car with just an ounce or so of product.
    We used a small bottle available at WalMart, Target and the like in order to measure our wax usage. Application was with a W9207 Soft Buff 2.0 Finishing Pad (7" diameter, flat face) on a G110v2 at speed setting 3. The wax was NXT Generation Tech Wax 2.0. The car in question is a 1999 (4th Generation) Chevrolet Camaro. Obviously something as small as a Mazda Miata will require a little less wax than this, while a Chrysler 300C will require a bit more.
    Let's get started.
    First we poured some NXT Generation Tech Wax 2.0 into the sample bottle, but we didn't bother filling it. We knew we wouldn't need that much.
    With our sample bottle holding more than enough product, we poured a bit of NXT 2.0 on the pad, distributing it over the surface.
    Not a lot of product, but enough to get us started.
    We covered half the hood with this first application.
    2nd application of product to pad.
    That pretty well finished off the hood and the entire front bumper. We also got started on the front fender with this application.
    3rd application of product. This got us most of the way down one side of the car.
    4th application of product.
    We finished off the first side and half of the roof. This car has glass T-Tops but we waxed those anyway, just to mimic having that surface area to cover on a regular hard top vehicle.
    5th application. As we did previously, just a thin line of product distributed across the face of the pad.
    This got the trunk, spoiler, rear bumper, other side of the roof, and a small bit of the rear quarter panel one side two covered.
    6th application. You can see how thin that line of product is.
    That finished off the quarter panel and most of the passenger door.
    With just part of the passenger door and front fender to go, we squeezed excess product out of the pad so that we could use it to finish the car. Here the tool is switched off and the pad is very firmly pressed against the paint.
    There's the product we managed to squeeze out of the pad.
    And we used it to finish off the car.
    We even went back over a bit of the door just to ensure complete coverage - no extra product was added at this point, however.
    Here's part of the door showing coverage. We went over every square inch of the car a couple of times at least, in different directions, to ensure full coverage. We didn't just give everything a quick brush with the pad just to make sure we could accomplish what we set out to do. No, we wanted to actually wax the car fully and honestly. Besides, we had too many eye witnesses. And a camera!!
    This coverage on the hood is pretty indicative of how the entire car was covered.
    Poor lighting here, but the spoiler and trunk are fully covered.
    And here's the 2.4 once bottle showing where we started and ended.
    And now for a bit of math to figure out what we used.
    The usable portion of the bottle is 3.125" tall. That works out to 0.768 ounces of product per inch of bottle.
    We used almost exactly 0.75" worth of product to wax this 1999 Camaro. That equates to 0.576 ounces of product.
    Yep, just over half an ounce to fully wax a car that size, with a fresh W9207 finishing pad on a D/A. The whole process took about 10 minutes and after letting the wax fully dry it wiped off with almost no effort at all with a single microfiber towel.
    So, are we saying you should only use half an ounce of product when waxing your car? Well, no. But to those of you who use 1/3 or 1/2 a bottle every time you wax we say "thank you!". But we also say "ease up, you really don't need to use so much!". In all seriousness, using the least amount of wax to get the job done is all you really need to use. No matter how thick you apply a wax there is only so much that will be left behind and bond to the paint. A heavy coat just takes longer to dry, is more difficult to remove and is simply a waste of product.
    Head Wax Monkey Black1's Avatar
    Oct 2010
    St. Joseph, MI
    102
    12
    Re: How to apply a very thin coat of wax with a G110v2
    Very informative, Michael.... Thanks.
    Would you say Next 2.0 spreads less, the same, or more than #26 Yellow?
    -Jake
    Better is a poor man who walks in his integrity than a rich man who is crooked in his ways. -Proverbs 28:6
    21,405
    1140
    You should be able to accomplish a similarly thin application using any of our liquid waxes, whether NXT 2.0, M26, M20, Deep Crystal Carnauba, etc.
    Sep 2005
    14,253
    538
    Great post, Mike. This should help out a lot of people. They should really be able to relate to how thin a coat of wax is needed.
    Registered Member rcktpwrd's Avatar
    Oct 2010
    Raleigh, NC
    293
    awesome write up!!
    When I recently did my PT with a DA for the first time, I was amazed at how little product went so far! I could never spread any wax/sealant product so thinly and evenly by hand before.
    1976 Cutlass S
    2001 PT Cruiser
    1990 454SS
    1989
    Suburban
    Aug 2008
    Harrisburg SD
    194
    14
    Wow, if every customer used it like I did before I seen this write up, Meguiars would be making some pretty good money off us! I have always wanted a write up like this. Thanks a bunch!
    . It depends on the condition of the car, but would Ultimate Compound use the same amount as the wax or a little more. I need to gauge my usage on Ultimate compound as well
    ______________________
    Tyler
    2002 Yellow Chevy Monte Carlo SS
    My Albums: http://s394.photobucket.com/albums/pp24/Johnson0667/
    MA
    122
    12
    Should we be going over the same area multiple times just like you do when doing paint correction? Generally with paint correction I do 2 passes "top to bottom" and 2 passes "left to right". When waxing, I don't generally do that much, but should I be?
    Sometimes I feel as if I'm not getting total coverage, but I also don't want to be over applying like stated so many times on these forums.
    21,405
    1140
    As an example, let's look specifically at applying wax to the hood of a vehicle. Since you can usually cover a lot of surface area with just a little product, you should be able to apply a small amount in overlapping passes (roughly a 50% pad overlap) in up and down strokes going from the leading edge of the hood to the cowl and back. Once that area has been covered in that direction, you can then go back over it in a side to side motion from the fender to the center line of the hood, still using a 50% pad overlap. Then do the other side of the hood the same way.
    Use this overlapping process, first one direction then the other, for each panel you do. That should give you good, uniform coverage over the entire vehicle.
    And remember, you're just using light to moderate pressure with the tool set on speed 3, but you're moving the tool over the paint fairly quickly relative to your movements when correcting defects.
    MA
    122
    12
    Awesome, that clears it up a lot. Thanks Mike.
    Dec 2010
    Amerongen Utrecht
    25
    Something naturally for myself!
    but This Amounth is really surpirsinly low :O
    i think last time i waxed my Golf i really smeared it all over till it turned grey:$
    but since its red and a free sample bag
    i tought why not but.! yes saves you a lot of time if done right!
    really also for my work! 45 minutes to wax on wax off! ><
  1. Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant
    Last Post: Sep 29th, 2010, 10:13 AM
  2. How To Get Great Results With Meguiar's Spray Wax!
    Last Post: Oct 19th, 2008, 05:57 AM
  3. ScratchX isnt strong enough
    By revjolly in forum Detailing 101
    Last Post: Aug 25th, 2006, 12:03 PM
  4. Using Meguiar's Even Coat Applicator to apply NXT Spray Wax
    Last Post: Aug 19th, 2006, 11:18 AM
