I just bought Troy Bilt pressure washer. Its 2600 psi, 2.3 gpm, Honda GCV engine and an axial cam pump.
It's not the best but it should serve my purposes for now.
My question is this pressure washer comes with 2 on-board detergent tanks. They each hold a half gallon (32 ounces). Do I fill the detergent tank with straight car washing soap, like Gold Class or do I need to reduce it with water? If I need to reduce it what ratio should I use? Gold Class is kind of thick, I'm not sure if the pump will pick it up. The owner’s manual is of no help as for detergent use. It says to refer to detergent's manufacture’s instructions.
Also any tips for getting a long life from this pressure washer?
Thanks fficeffice" />
