What size Foam Pad Cleaner would you like as a stand alone product?
View Poll Results: In what size should we offer Foam Pad Cleaner One-Step?
Voters
39. You may not vote on this poll
  • 10 oz
    6 15.38%
  • 12 oz
    5 12.82%
  • 16 oz
    28 71.79%
Results 1 to 10 of 10
Thread: What size Foam Pad Cleaner would you like as a stand alone product?
    21,402
    1138
    As you probably know, our new Wheel Polishing Kit contains not only the very cool DynaCone Polisher, but the new All Metal Polish and Foam Pad Cleaner One-Step, each in 4 ounce sizes. We also introduced the All Metal Polish as an 8 ounce stand alone product but have yet to do so with the Foam Pad Cleaner One-Step. Of course, this product by itself is generating a lot of buzz due to it's highly effective cleaning ability after polishing bare metal, as shown in this thread.
    So, if we do introduce Foam Pad Cleaner One-Step as a separate product, what size do you think makes the most sense? What size would you be most interested in?
    Take the poll above, and feel free to chime in with any comments as well.
    1991 Honda Civic Si therdrman's Avatar
    Oct 2010
    Canada
    27
    311
    Re: What size Foam Pad Cleaner would you like as a stand alone product?
    bigger is always better right?
    Aug 2010
    Memphis, TN ~ USA 1
    458
    15
    Quote Originally Posted by therdrman View Post
    I hope not
    Oct 2010
    Canada
    27
    311
    ^ hahaha lol. im talking about the size of the bottle. i am assuming your not?
    Registered Member Woodie6250's Avatar
    Dec 2007
    Johannesburg, South Africa
    211
    15
    If I remember correctly from the original thread, this Foam Pad Cleaner is specifically for cleaning the Dynacone and is not recommended for use with the standard Soft Buff pads. This would be my indicator of how often I would use the product - if it was a general pad cleaner for all foam (including Soft Buff) then I'd say the bigger the better as I'd be using it quite often.
    However, as it's a Dynacone specific product, and you'll need +-1oz for each time you clean the Dynacone, my vote goes to the 10oz option. For normal consumer use, the wheel polishing kit won't be used on a weekly basis, and probably less than once a month. A 10oz bottle will give you 10 "cleans" and for the average consumer will last for more than a year.
    Obviously if you are polishing wheels for customers then you'll need a lot more cleaner and will probably be wanting the cleaning solution in Mirror Glaze size options.
    Oct 2010
    Canada
    27
    311
    i dont understand why. people would want a smaller bottle. if it is bigger it will last longer
    Aug 2008
    Savannah
    191
    14
    As was previously stated, if this would clean all foam pads then the bigger, the better.
    Feb 2010
    Suffern, NY
    28
    2,841
    54
    Gallon?
    Tedrow's Detailing
    845-642-1698
    Jul 2011
    Seminole Florida
    14
    How would you clean the dynacone if you run out of the cleaner?
    Registered Member ethereal45's Avatar
    May 2011
    Nebraska
    471
    14
    Assuming this is compatible for all pads, I would say the biggest size possible, for this reason:
    Bigger size bottle almost always = less cost per ounce. Since something like a pad cleaner would be viewed as a "luxury item" since you can do the job with soap and water, I would want to spend as little on it per ounce as possible. I'm assuming it will have some magical ingredients that really help break down spent product and residue that clings to the inside of the foam. I've used products like DP Foam Pad Cleaner/Rejuvinator, and while they do work very well, they just seem like alot of money spent on something I can do just as easily (albeit, with slightly more work) without such expensive products.
  1. Replies: 6
    Last Post: Nov 20th, 2010, 05:34 PM
  2. How to apply product to the face of your foam buffing pads
    Last Post: Mar 6th, 2009, 11:13 PM
  3. What causes the buffer to hop?
    By sellncars in forum Machines - The Rotary Polisher
    Last Post: Oct 4th, 2005, 09:04 PM
  4. Light scratches on black 05 GT
    By fun69Mach1 in forum Machines - The Dual Action Polisher
    Last Post: Apr 29th, 2005, 11:01 AM
  5. How to hide/remove medium scratches??
    By yogibear458 in forum Detailing 101
    Last Post: Apr 10th, 2005, 12:33 PM
