Best way to dry a Black/Dark car?
Results 1 to 10 of 13
Thread: Best way to dry a Black/Dark car?
    May 2008
    Miami, FL
    7
    12
    Is "the Absorver" OK to use for drying a black car? Will it leave swirls?
    What would be the best way/product to dry a black car?
    Dec 2010
    Comerio Puerto Rico
    129
    Re: Best way to dry a Black/Dark car?
    My car is white but I use the waffle weave drying towel because the absorver and the other chamois are very flat so when drying if tiny "rocks" or dirt not are removed then when the chamois caught it, it will be riding along your paint and making swirls. the waffle weave can caught it and hide this particles inside it more easy than chamois. After all is made of micro fiber. Also fo a car after 3-4 uses of waffle weave or after washing the waffle weave it absorb a lot. I only dry all my car without taking the water out the waffle weave.
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    60
    The color of the car doesn't matter. Swirls and cobwebs appear on all paint colors, it's just easier to see them on darker colors because of the contrast between the base coat and clear coat when the light refracts off of it.
    As for drying methods, use the least invasive method as possible. My own method is to "pat" dry the car using waffle weave microfiber drying towels. The idea is that patting the towel eliminates the friction resulting from dragging a towel across the painted surfaces. This follows a flood rinse which serves to remove most of the standing water from the surface of the paint.
    For horizontal surfaces, I lay several towels across the surface and lightly pat or bat the towels with my open palms. For vertical surfaces, fold the towel into quarters. Gather up the open ends in your free hand and lightly bat the towel against the paint.
    May 2008
    Miami, FL
    7
    12
    Great answer and very detailed!
    What kind of towel (type and/or brand name) is best for initial drying and minimizing swirls on a new but swirled black/dark car?
    Thanks - Just got swirlx and colorx.
    Quote Originally Posted by ClearlyCoated View Post
    Swirl Terminator neuralfraud's Avatar
    Apr 2005
    36
    15
    Rogan,
    as said, a waffle-weave microfiber towel is your best choice for two reasons, simple - easy to find, safe - very gentle and will prevent particles from simply being dragged against the surface. If you want a specific towel, I personally use the Meguiar's "Water Magnet". This is a fine quality waffle-weave type microfiber cloth that absorbs very well.
    I personally own a black Pontiac G8 and that is what I use to dry it. As long as you wash properly, you shouldn't need to worry about particles.
    The best way to dry a car is to simply rinse the car with low pressure water directly from a hose (no nozzle) to promote sheeting which will remove 95% of the water, then you could gently pat the remaining water to absorb it. After that is done, unless you need to clay the car immediately afterwards, you can use a quick detailer to remove any water residue/spotting and leave a high gloss shine!
    Hope that helps.
    Jan 2009
    San Diego, CA
    2,310
    60
    Quote Originally Posted by Rogan01 View Post
    I use Meguiars water magnets as described and linked in the above post by neuralfraud.
    Also, do yourself a favor and watch this video by Mike Phillips. How to Wash Your Car Show Car Style. If I remember correctly, this video is where I first learned of the pat drying method.
    May 2008
    Miami, FL
    7
    12
    Thank you. I will look for that product!
    Is The Absorber harsh on the finish or OK?
    Nov 2009
    South TX
    192
    Personally I dont like the Megs WW for drying my personal vehicle... My finish is always near perfect and with the soap I use it is Sooooo slick that a good cobra mf 75/25 is all I need. Tried the pay down method but it's a little time consuming for me.
    If you wash your vehicle and remove all the dirt and rinse and flood followed with a spritz if QD or UQW it will make drying so much easier. Not sure what it is about the these additives but my mf holds and wipes water away much better. Not saying cobra mf pick it up in one pass but I do get about 90% and then a quick wring of the towel and it's all nice and clear as the additive finishes streak free
    Just my two cents
    Detailing Dunce akimel's Avatar
    May 2008
    Roanoke, Virginia
    2,378
    149
    I often use the Absorber, but I do not rub it on the paint; I blot the water.
    --Al Kimel
    is dazed & confused TLMitchell's Avatar
    Oct 2008
    Southington, Ohio
    64
    274
    14
    I keep an Absorber around for large areas of non-painted surfaces like tonneau covers. I quit using them when I discovered WW MFs. I never did find them to remove the last traces of moisture and found they picked up and retained any slight grit that may have been missed.
    The "best" way of drying, IMO, is the one that gives the least chance of swirling or marring... which means the less touching you do the less chance you have of incurring any marks. I have a detachable blower on my Shop Vac and use it to blow the water off after rinsing. I used to flood-rinse but when blowing the water off it skeedaddles across a finish with decent LSP on it better when it beads. A blower also allows you to blow out the door jambs and other nooks and crannies. Nothing worse than driving down the road in a recently washed black vehicle with dribbles running down the side from mirrors and trim leaving watermarks.
    I finish off any residue with a WW in each hand... one high quality and one utility WW for rockers, fender lips, jambs and places where some stray grunge might be lurking. The WWs never get wet enough to ring out since the blower takes care of the bulk of the water.
    On darker vehicles I often finish-wipe using a QD or UQW for a better, more polished result.
    TL
  1. The Protection State of Mind
    By HealthyCivic in forum Detailing 101
    Last Post: Oct 1st, 2010, 11:16 AM
  2. Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant
    Last Post: Sep 9th, 2010, 06:25 PM
  3. Nissan Sentra - Extreme Makeover
    By Mister B in forum Show Off Your Latest Detail Work
    Last Post: Jul 30th, 2010, 03:36 AM
  4. autoLavish: from Race Car to Show Car - GTS3 993 RSCS
    By jlb85 in forum Show Off Your Latest Detail Work
    Last Post: Jul 20th, 2009, 08:05 AM
  5. Importants Questions need to be answered??
    By aref in forum Detailing 101
    Last Post: Oct 26th, 2006, 06:22 PM
