Using Meguiar's D/A Microfiber Correction System
This is a sticky topic.
  • Re: Using Meguiar's D/A Microfiber Correction System
    Michael,
    I may just use the D300 with light pressure to remove light scratches/swirls and follow up with M205 and Ultimate wax. Just waiting for the weather to average atleast 65 degrees. I'll keep studying for more tips and tricks before I start.
    Wig
      Just wanted to let you guys know that a few days ago we published a review of the DA MF System at Solodetail.com detailing blog. It's written in Spanish, so the original version is for those of you that can read that language. But click here for an automatic translation by Google that makes it understandable in English.
      We liked the system very much and it's amazing what it can do. Here's a little teaser:
        ^^ Great review - thanks for sharing!
          Michael,
          After you officially released the M/F system, somebody from Megs posted pictures and comments about how the MF pads and work was posted on this forum in disguise. Are you aware of this? Can you point to those posts?
            Originally posted by ronniejay View Post
            Michael,
            Ah yes, the Dodge Ram "Super Bee" we did just prior to SEMA 2009 We made fairly extensive use of early prototype variations of the DA Microfiber System and Kevin Brown revealed it later on. You can see part 1 of that project here and follow links to the later installments.
              I just recived the 5" D/A Microfiber starter kit today so roll on the weekend
              Have A Smurfie Day
              Take Pride In Your Ride...
                Well... How was it? Pros, Cons, Ups, Downs???
                  You can, but the idea behind the Finishing Wax in this system is for fast application, even faster drying, and incredibly fast (as in one wipe) wipe off. The Finishing Wax and microfiber finishing disc also work together to remove any hazing that may have been created by the Cutting Compound and microfiber cutting disc.
                  Normally when this system is broken up or hybridized with other products we see (and actually recommend) people using the compound and cutting disc to do the major defect removal first, then follow up with something like M205 on a foam finishing pad to refine the finish further, and then finish with the wax or sealant of their choice on a fresh foam finishing pad. But if you choose to experiment with any other wax/sealant on the microfiber finishing disc and you like the final result, we certainly won't tell you that you're wrong.
                  Thanks for the reply - What I guess I'm asking is there and danger to the paint or the pads buy deviating from the 301 use if I'd like to?
                  2018 Subaru Outback 3.6R Touring - Crystal White Pearl
                    No, not at all. We've seen people use M105 with the cutting discs, D300 with foam pads, etc. The system may have been developed as just that, but people like to experiment and play around with different combinations. Doing so, at the end of the day, is just mixing well known liquids with well known pads and the worst that usually happens is that you don't get quite the result you were hoping for. Even when you encounter very delicate paint that hazes badly with a very aggressive combination, it's more a matter of frustration than anything else. You've done no real damage, you've just made more work for yourself because you now have to go back and clean up the hazing. But that can happen at almost any time, with any combination of products, if the paint just doesn't like that combo. Such is the world of paint polishing!
                      That's what I was wanting to know, thanks.
                        Michael,
                        What would have more cutting power, Ultimate Compound with the MF cutting pad or D300 with the MF cutting pad?
                        I guess my another part of this question would be simply - is the extra cut power in the MF pad or the D300?
                        I have a Fox Body Mustang that has had some paint work and the repaint area clear is VERY hard. I was able to correct the factory paint last year using UC an a foam pad but when I came to the repaint area I could not get full correction, even with multiple passes. I am close to ordering the MF system but am wondering if I should just order the pads?
                        Thanks in advance!
                          Originally posted by KeithIndy View Post
                          Michael,
                          Thanks in advance!
                          D300 will have more cutting power than Ultimate Compound.
                          The MF cutting pads are more aggressive than the W8207 foam polishing pads. The selection of the MF cutting pads along with the D300 correction compound will make it a lot more aggressive than the UC with the W8207 foam polishing pads.
                            Thanks Marc, that answers my question.
                            I am wondering, since I don't fit the target market for the microfiber system and I am not really interested in saving time with the two step process, if I would be just as well off if I purchased some MF cutting pads and some D300? That would give me the cut I need beyond the UC / W8207 pads I am using now. I could then follow it up with a foam pad and Ultimate polish or Ultimate compound if I had to. Lastly, top it with my favorite sealer / wax.
                            I think the whole MF system, for me, would be a waste as I am just a weekend detailer, not someone looking to bang em' out for money.
                              [QUOTE=wig;495078]Michael,
                              Finally got around to detailing my car with the D/A MF system, M205 and the new liquid wax and the results are spectacular! I'll try to uploads some pics later but you can walk through my silver finish that is wet and super glossy... Can't wait to get it on in some sunlight
                              Wig
                                [QUOTE=wig;500153]
                                Originally posted by wig View Post
                                Michael,
                                Wig
                                Did you use both steps of the MF system or just D300 / Cutting pad?
