Using Meguiar's D/A Microfiber Correction System - Page 6
Page 6 of 23 FirstFirst 123456789101112131416 ... LastLast
Results 51 to 60 of 225
Thread: Using Meguiar's D/A Microfiber Correction System
  1. #51
    May 2008
    chicago
    48
    12
    Re: Using Meguiar's D/A Microfiber Correction System
    My question, which seems obvious, is that we all know when applying a sealant you want to apply it to clean wax free paint. If using the finishing wax in this system and since it has carnauba in it, wouldn't you be cutting the durability of the sealant you use if you're putting it on top of the finishing wax?
  2. #52
    21,402
    1138
    Quote Originally Posted by never gone View Post
    That totally depends on the sealant. While some manufacturers will stress that you only apply their products to a "perfectly clean surface" free of other waxes, polishes, etc we have never said that about our waxes and sealants. That said, if you have a favorite sealant that you want to use and are making use of this system as well, you have a couple of options:
    • Do the correction with D300 Compound and the Cutting Disc, follow with D301 Finishing Wax and the Finishing Disc to refine the finish, then give it an IPA wipedown and then apply your fave sealant
    • Do the correction with D300 Compound and the Cutting Disc, follow with M205 on a foam finishing pad, (or any other finishing polish you might like) and then top with your sealant
  3. #53
    May 2008
    chicago
    48
    12
    I just bought some 205 a few week ago so that's perfect. Thank you.
  4. #54
    Registered Member Jonesey's Avatar
    Nov 2005
    51
    149
    16
    I remember seeing in one of the reviews that this system was used on a boat (looked like a show boat) Any idea how it will work on gelcoat that has actually been outside Is Meguiar's working on compounds for the marine line to work hand in hand with the pads?
    Glenn
  5. #55
    Oct 2010
    New Orleans, La
    61
    Does d300 or 301 stain trim? Do we need to tape up the plastic trim? Also I have a 6" GG. Which size pad: 5" or 6"?
  6. #56
    21,402
    1138
    Quote Originally Posted by Jonesey View Post
    Glenn
    While the system does tend work very well on gel coat, that surface can pose some interesting challenges at times. As you probably know, gel coat is not only much thicker and harder than automotive paint, it's also a lot more porous. If the gel coat is very old and badly oxidized and dried out, it may draw a lot of the lubricant out of the D300 and dry it up. That's probably only going to happen in extreme cases, and will be similar to using some of our Marine/RV products on such a "worst case" finish. An initial application of M45 Pure Polish first may help in those situations.
    Quote Originally Posted by success View Post
    Yes, they will stain trim so taping off is recommended. But another nice thing about these discs is that you can easily get right up against edges, trim, lights etc without tending to overlap them like you do with a foam pad. If you're using the Griot's D/A, stick with the 5" discs on their standard backing plate. You can also use the 6" discs but we would then recommend moving up to our S6BP backing plate.
  7. #57
    Formerly "n737nc" Nick Chapman's Avatar
    Sep 2006
    Dallas, Texas
    48
    2,710
    312
    I did some experimenting with backing plates on the Griot's machine, and found that the W67DA backing plate works the best with this machine. The 6" is just too big for the DA, works soooooo much better using the 5" platform!
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
  8. #58
    Pray for our country
    North Carolina
    3,683
    87
    Will the larger pads work with the old hook & loop backing plate that came with my G-100 from circa 1999? (Yes, I still have that plate, and it still works fine )
  9. #59
    21,402
    1138
    You shouldn't have any problems with that circa 1999 backing plate.
    Frugal, aren't you?!
  10. #60
    Dec 2009
    USA :)
    131
    12
    Michael,
    Is the diameter of the 3" backing plate exactly 3"?
  1. DA Microfiber Correction System
    By Show 'N' Shine Car Detailing in forum Detailing 101
    Last Post: Apr 23rd, 2013, 02:11 PM
  2. DA Microfiber Correction System
    By Charger10 in forum Machines - The Dual Action Polisher
    Last Post: Apr 22nd, 2012, 07:54 AM
  3. DA Microfiber Correction System
    By DeanK in forum Detailing 101
    Last Post: Jul 21st, 2011, 09:09 PM
  4. Meguiar's New DA Microfiber Correction System Part #2!!!
    By Tim Lingor in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Apr 24th, 2011, 11:07 AM
  5. Microfiber DA correction system... HERO or ZERO?
    By Superior Shine in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Mar 6th, 2011, 08:10 AM
