Introducing our new DA Microfiber Correction System
  • Re: Introducing our new DA Microfiber Correction System
    i use the DA at work on my own car and wow it looks like its new the car is 98 ford expo and its looks good .. Revi from south gate
      The current pad selection does work with the Cyclo, you just need to source different backing plates for that tool to accommodate our 3.37" pads.
      At the risk of sounding a bit abrupt, you really should read through the reviews on this product - answers to all over your questions have been answered several times. But in short, yes, the Finishing Wax is a cleaner type wax, especially when coupled with the microfiber Finishing Disc, and it will very quickly clean up even the worst haze left by the compound and cutting disc.
      Does the D301 Finishing Wax uses SMAT Abrasives too? Or its just a chemical cleaner wax type? Thks.
        SMAT Abrasives.
        Andrew Scruton-Wilson
        Latin America Training Specialist
        Irvine, California
        alwilson@meguiars.com
          Quick question. I'm planning on buying the G110V2 and the Microfiber pads. Does the backing plate supplied with the G110V2 work with the microfiber pads? Autogeek says the G110V2 comes with "Meguiars W68DA Soft Buff 2.0 DA Backing Plate" and that is not listed in this article. Do I need to buy a new backing plate? What size works with the G110V2 and what is required to make it work? Autogeek says its a 6" polisher, but this article says the 5" pads are perfect for the G110V2. If I want to use a 3" pad for the pillars, I assume I need a different backing plate.
          As always, any help is appreciated!
            The W68DA will not work with the microfiber system. You need to get new backing plates.
            3" MF Pads: S3BP Backing Plate
            5" MF Pads: W67DA Backing Plate
            6" MF Pads: S6BP Backing Plate
              Thanks for the speedy reply. Man was it hard to find a place that had the DA, DMC5, DMF5 and the W67DA in stock and ship to Canada. Ebay failed me, amazon failed me, autogeek failed me. Had to order G110V2 from autogeek, along with the DMC5 and DMF5, and order the backing plate from an ebay seller I bought some meguiars stuff off of in the past. Amazon wanted $25 to ship the backing plate!!!
              I'm so excited to get the stuff, hope the Canada Post strike/slow mail clears up. I recently did a full detail on my car, only for a truck to back into it while it was parked. I told the repair shop not to touch the rest of the car - and of course they did. Swirls and hologram galore again! UGH!!! It's killing me!
                hi guys i do have g220 and i bought the 5" correction kit last time and it did a great result but it s hard for me to finish the entire car faster. can i save time on the 6" correction pad? are their cutting ability the same?
                XTREME AUTO SPA more than a carwash...
                MEGUIAR'S PHILIPPINES Cabanatuan City Detailer
                  I would stick with the 5" kit for your D/A. That pad size was specifically designed for the D/A's oscillating action. The 6" should be mainly used for the Flex 3401 or Pneumatic sanders.
                    ah.. okey thanks bro. i'm planning to buy another d.a. (meguiars g220v2). what pad should i buy? a 5" or 6" correction kit?
                      You definitely want the 5" system with a traditional style DA. That's what the whole system was engineered around for optimum performance: 5" discs on a G110v2 (G220v2 in your part of the world) at speed 4 (4800 opm) for cutting and speed 3 (3800 opm) for finishing.
                        wow thanks sir mike for your quick reply... I'm a bit confused what to order coz meguiars philippines were using the 6" on a g220v2 on my training on Mf correction system.
                          Noobie here. Used the DA Microfiber System on my car with great results. Quick question. I've read that these pads are machine washable. What's the best procedure for machine washing the DA pads?
                            Toss 'em in the washer and dryer along with your microfiber towels. Liquid laundry detergent, warm wash, cold rinse, then dry on low heat and you'll be good to go. As always, no fabric softener and no dryer sheets when cleaning microfiber materials.
                              Hi,
                              English is my second language.
                              Referring to DA Microfiber Correction System, I am hard of hearing one sentence..
                              This section 4:35~4:39 : This specially engineered microfiber pad allows you to refine surface to high gloss while(?) a wine(?) protection.
                              Please help me.
                                "...refine the surface to a higher gloss, while applying protection."
                                David
