Advice Needed...
Results 1 to 3 of 3
Thread: Advice Needed...
    Dec 2004
    18
    17
    Advice Needed...
    I just got a PC and some #80. Should I go with clay, #80, and 2 coats of nxt, or should I also use my DC paint cleaner before #80?
    Registered Member Rockpick's Avatar
    787
    25
    Hi turbodreamer...
    Either way is acceptable.
    My suggestion is to try both methods to see which may work best for you and your individual paint finish. To do this, I would put a strip of masking tape down the center of your hood. Do half of the hood with the DC/#80 combo and do the other half with #80 alone.
    Once I had applied to both sides, I'd pull it out into the sun to assess the finish. Based on those observations, I may or may not continue with the DC.
    I hope that helps out a bit! Please let us know if you should have any other questions!
    -RP-
    I want this car. Boss_429's Avatar
    355
    21
    I would agree with RP........... give both a try. Using the #80 prior to NXT might give a tad different final appearance. Also, keep in mind, that #80 will remove some fine swirls that DC1 won't touch. So, if you have swirls, then theres not much of a choice......... go with #80.
    Boss_429
  1. Advice needed on OEM paint
    By zaidgreat in forum Detailing 4 Dollars
    Last Post: Aug 18th, 2008, 10:06 PM
  2. New tire advice needed please.
    By Jonesey in forum The Break Room
    Last Post: Sep 17th, 2006, 12:01 PM
  3. some G100 advice needed, please help
    By 2002FX4 F150 in forum Machines - The Dual Action Polisher
    Last Post: Jul 17th, 2006, 03:51 PM
  4. Your advice and recommnedations needed.
    By StraySheep in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Mar 15th, 2005, 11:08 AM
  5. Advice Needed
    By jfwebber in forum Detailing 101
    Last Post: May 1st, 2004, 06:14 AM
