Ultimate Polish Review!! - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: Ultimate Polish Review!!
  1. #31
    Sep 2005
    Sydney, Australia
    4,289
    63
    Re: Ultimate Polish Review!!
    ^^ True kristina, but the polishing step is still optional.
    You can move straight from SwirlX or UC to wax if desired. Whether or not polishing makes a visible difference is debatable, especially on modern clear coats and/or on lighter coloured cars.
  2. #32
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    Quote Originally Posted by kristina27 View Post
    If I remember right swirlx is made to remove minor swirls an defects it has cutting power. Not quite as much a ultimate compound it is the least agressive of the two. Swirlx is not advertised as a polish so comparing swirlx and ultimate polish side by side is not a true comparison . I believe you are to use the swirlx first to remove minor swirls and defects and then apply the ultimate polish as a next step to polish and bring out the color in the car. Which then is followed by a wax or sealant. So if you were to look at the order of things. Swirlx or Ultimate compound (which ever is needed for you paint condition) then Ultimate polish and finished with Ultimate wax.
    A comparison of Ultimate Polish and Swirlx is a fair comparison since Swirlx has about the same cut as M205. Both are advertised and used to remove minor swirls. Ultimate Polish has maybe slightly less cut than 205 and a little less cut than Swirlx. They are similar products that are designed as a follow up to Ultimate Compound verifying the legitimacy of my comparison.
    PS Swirlx and Ultimate compound fall under the painter cleaner categories. They prepare the painter for polishing (Ultimate Polish) and then waxing
    Swirlx is actually a cleaner/polish with no where near the same cut as Ultimate Compound. One is a compound and the other is not.
  3. #33
    Registered Member kristina27's Avatar
    Abilene, Kansas
    96
    9
    In my experience I have never used M205 so I can not comment. I guess the point i am trying to make is that Swirlx and ultimate polish each do better at one thing over the other. Yes polishing is an optional step and swirlx has polishing attributes as well as Ultimate Polish has cutting attributes. I was simply trying to say that both are better at doing something different. Swirlx is better for cutting and removing minor defects with the a polishing attribute if you want to go directly to the wax step. Ultimate polish is made more for polishing. It does have a fine cutting side if the defects are really minor. In my mind I do not have the expectation that both will perform and result similarly. I would use swirlx to remove swirls and Ultimate polish to polish. I guess that's my thinking during the detailing process. What it really comes down to is what you want, the kind of condition your paint is in and the time you have. For some swirlx with a little polishing does just fine or using a cleaner wax and others may want to do the whole shebang swirlx, ultimate polish and wax.
  4. #34
    Dec 2009
    Iowa
    2,633
    39
    I haven't had to do a time or cost sensitive project, so I enjoy the whole shebang. However lately, the whole shebang has been changing with the addition of new products and processes. I bought some SwirlX at reduced prices awhile back, but I haven't touched it except for test areas. I had been using it on ever job.
    David
  5. #35
    Apr 2011
    Edmond,ok
    27
    9
    UC, swirlx, and this product all left swirls on my truck had to be professionally fixed.. mothers is the way to go.. these products are worthless
  6. #36
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    Quote Originally Posted by outsideshot23 View Post
    I showed you the sun shots. I showed you the process. Did you see any added swirls? I sure didn't.
    Care to qualify this statement with a brief story of your troubles?
  7. #37
    Jan 2009
    New Lenox, Illinois
    10,362
    300
    I dont think you will be getting much help in your "help" thread if you keep making similar posts like the above.
    Detailing my Black VW
    Apr 2010
    UK
    460
    14
    Great review Shawn . Cant wait to try the Ultimate polish on my black pearl.
  9. #39
    Apr 2011
    Sault Ste Marie ON
    9
    Shawn,
    In regards to the light swirl marks how did the UW handle them? Did it eliminate them?
    I have a 2010 Santa Fe which has a candy apple color (Venetian Red) and has some light swirl marks which I attribute to the Turtle Ice I used. This was recommended by a friend and although I have been a Meguiars user for years I thought I would try.
    Big mistake.
    Would like to hear how the UW handled the swirl marks?
    Thanks
  10. #40
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    Quote Originally Posted by SFLTD View Post
    Shawn,
    Big mistake.
    Thanks
    Do you mean Ultimate Polish or Ultimate Wax?
    Ultimate Polish did a fair job at reducing the swirling but it did not eliminate all the swirls which an only be expected when working with a finishing polish by hand.
    Ultimate Wax does hide swirls well though. Might want to check my review of Ultimate Wax to see how well it hid the swirls.
  1. Ultimate Compound
    By Tuck91 in forum Consumer Line - Product Reviews
    Last Post: Aug 17th, 2011, 06:05 PM
  2. Another Ultimate Quik Wax Review (Pictures)
    By Carfire in forum Consumer Line - Product Reviews
    Last Post: Feb 14th, 2011, 10:18 AM
  3. Ultimate Comp & polish
    By Lightseeker in forum Detailing 101
    Last Post: Sep 6th, 2010, 05:59 AM
  4. Another Ultimate Quick Wax review!
    By 02zx9r in forum Consumer Line - Product Reviews
    Last Post: Mar 11th, 2009, 03:40 AM
  5. Arguments vs. Zaino
    By phenomic in forum Detailing 101
    Last Post: Jun 2nd, 2006, 12:05 AM
