what is the best way to remove bird dropping stains on my vehicle. my car is painted black ?
bird droppings
Re: bird droppings
I would suggest using Meguairs Quick Detailer or Meguiars Final Inspection and a Supreme Micro Fiber Towel.
Mist either of the products mentioned above directly on the dropping allowing it to saturate. Make sure to use enough product because of the amount of grit known to be in bird droppings. Taking you MF towel folded in 1/4ths place it on top of the dropping and lightly swipe it of. Be sure not to apply to much pressure, just swipe....then using another clean MF towel remist the area, wipe then flash dry.......
