Porter Cable D/A Polisher Sander w/ hard case
  • Porter Cable D/A Polisher Sander w/ hard case
    I'm selling a Porter Cable 7335 5" HD variable speed random orbit sander which is basicaly the same as the 7424 with a change of accessories. Its really like new, has a hard case and bunch of accessories. $125 + ship. I can send you pics email detail@optonline.net
    I figured that this was a good article to post for you all....
    This article covers the following Porter-Cable tools:
    The 7335 5" & 7336 6" Random Orbit Sanders and the 7424 Car Polisher.
    These tools are essentially identical in that they all use the same body. The difference lies in how these tools are outfitted. Therefore, if you own any one of the above models you have the capability to convert it into either a 5" or 6" sander/polisher. But before you can proceed you must understand that depending on the pad diameter one of two counterweights is used.
    The counterweight is a half-moon shaped piece of metal attached to the rotating shaft of the tool. This smooths out the random orbit action by providing a counter balance to the elliptical orbit of the rotating backing pad. If you change the pad size you must also change the counterweight or suffer unnecessary vibration and possible damage to the tool.
    There are two different counter-weights which are clearly marked to indicate use with either the 5" or 6" backing pad. Therefore if you decide to outfit the 7335 5" Sander with a 6" backing pad for sanding or polishing you must switch to the counterweight used with 6" backing pads. The same goes for the 7336 6" Sander. If you decide to outfit it for 5" sanding or polishing you must switch to the counterweight used with 5" backing pads.
    Porter-Cable 7424 CAR POLISHER The only exception is when using the 54745 6" Foam Polishing Pad. Due to its light weight and the small-diameter backing pad used (included with pad), it can be used with the 5" or 6" pad counterweight. Porter-Cable outfits the 7424 Car Polisher with the 5" pad counterweight.
    Re: Porter Cable D/A Polisher Sander w/ hard case
    Any foam pads or backing plate accessories with it?
      Its set-up as a sander. It needs the parts listed (counterweight and pads) to convert to a polisher.
