Meguiar's Quik Tips Video Series - Restoring Neglected Headlights
Results 1 to 10 of 12
Thread: Meguiar's Quik Tips Video Series - Restoring Neglected Headlights
    Director of Global Training, Events & Consumer Relations Mike Pennington's Avatar
    1,706
    35
    We are proud to announce the 2nd of several new Quik Tip Videos for 2011 !
    Restoring Neglected Headlights featuring our Heavy Duty Headlight Restoration Kit.
    After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
    _________________
    Plastic headlights come in a variety of shapes, sizes and even conditions. While some are crystal clear, others are lightly cloudy & hazed and some are just plain neglected.
    Depending on the condition of your headlights, we offer a variety of solutions to easily restore and protect your headlights for maximum visibility and overall appearance.
    For neglected and heavily oxidized headlights, we recommend Meguiar's Heavy Duty Headlight Restoration Kit. This kit includes everything you need to improve clarity and safely restore neglected headlights to a like new appearance.
    To use our Heavy Duty Headlight Restoration Kit, start by cleaning your headlights to remove any loose dust, dirt or debris.
    We recommend taping off the edges of your paint for added protection.
    Attach the 1000 grit finishing disc to the included hand pad.
    Lightly mist the headlight and finishing disc with water and begin sanding the neglected headlight in a side to side motion.
    Continue sanding in this uniform motion until the headlight appears evenly frosted.
    Once this is achieved, remove the 1000 grit finishing disc and attach the 3000 grit finishing disc to the hand pad.
    Lightly mist the headlight and finishing disc with water and re-sand the headlight thoroughly in an up and down motion using smooth overlapping passes.
    For best results, continue this up and down sanding motion until the headlight has a uniform lightly frosted appearance, then wipe off any residue.
    Attach the Meguiar's specialized buffing pad to any drill.
    Apply a small amount of Meguiar's PlastX polish directly on the buffing pad.
    Place the pad flat against the headlight and turn on the drill.
    Use slow overlapping motions while keeping the pad firmly against the headlight while buffing.
    Re-apply PlastX polish as needed and continue buffing until the headlight becomes crystal clear.
    Apply and remove PlastX polish by hand to reveal a like-new headlight that's brighter, safer and better looking.
    For long term clarity and protection, apply and remove the included Meguiar's Headlight Protectant.
    Like new clarity in no time at all with Meguiar's Heavy Duty Headlight Restoration Kit.
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
    Registered Member rcktpwrd's Avatar
    Oct 2010
    Raleigh, NC
    293
    12
    Re: Meguiar's Quik Tips Video Series - Restoring Neglected Headlights
    great video!
    looks like its a fairly easy to use system.
    1976 Cutlass S
    2001 PT Cruiser
    1990 454SS
    1989
    Suburban
    KC thedetailers KC's's Avatar
    Jul 2009
    kuala lumpur Malaysia
    1,610
    526
    great stuff
    May 2011
    Modesto, Ca. 95356
    9
    manny3700 I saw the video very informative. I will apply what I have seen. Thank you. Where should I purchase the product online or at a store? thanks!
    1,706
    35
    On-line or a local store either way.....
    If you try a local store, give your closest Advance Auto Parts or O'Reilly Auto Parts (used to be Kragen) a call.
    Make sure and ask for the Meguiar's Heavy Duty Restoration Kit in the yellow box....NOT our One-Step Kit....
    If you go on-line to search, the part # is G3000
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    Aug 2010
    Fairmont, MN
    76
    1,431
    24
    Any chance of the 'Protectant' being available as a stand alone product?
    Thanx...
    Bill
    1,706
    35
    Always a chance, but not in the very near future, but will certainly pass along the comment to Mktg.
    That said, the 4 oz bottle that comes with the headlights will roughly do 2 headlights approx 12 - 16 + times....Remember, thin thin coats is all you need.
    Hope this helps !
    If you do happen to run out, and need some extra protection, try any of our waxes. That will add some protection as well !
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    Aug 2004
    Glendale, AZ
    35
    2,962
    51
    Quote Originally Posted by Mike Pennington View Post
    Hope this helps !
    How is this plastic sealant different from your regular synthetic wax sealants like NXT 2.0 or Ultimate Wax?
    1,706
    35
    Quote Originally Posted by Marc08EX View Post
    Similar technology, but of course the product is designed to work on clear plastic surfaces, not a painted surface. That means some of the characteristics our R & D team builds into formulas needed for paint are not needed on clear plastic and visa-versa....
    That is why a good coat of wax could also be used in a pinch if needed.
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    Registered Member jarred767's Avatar
    Jan 2007
    Bend, OR
    36
    687
    19
    I've just used 3" pads w/ my DA and plastX with good results, but this could be useful for really neglected headlights. Can the included yellow pad be bought individually, and is it compatible with a DA? Does it work better/have any advantages over a 3" polishing pad? And roughly how many headlights should this pad hold up for? Thanks in advance.
    Dynamic Detailing
    541.668.0480
  1. Meguiar's Quik Tips Video - The 5 - Step Paint Care Cycle
    By Michael Stoops in forum Meguiar's Videos
    Last Post: Jul 3rd, 2018, 12:49 PM
  2. Meguiars Online Acronyms - Product Links
    By gb387 in forum Discussion Forum Related Basics & How To Articles
    Last Post: Mar 23rd, 2016, 09:12 AM
  3. Introducing Meguiar's Quik Tips Video Series
    Last Post: Feb 12th, 2013, 04:12 AM
  4. Questions about #7 Glaze and GC Wax
    By rdv350 in forum Detailing 101
    Last Post: Jul 5th, 2005, 08:50 AM
