Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
Results 1 to 10 of 11
Thread: Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
    21,402
    1138
    We are proud to announce the 3rd of several new Quik Tip Videos for 2011 !
    Quick and Easy Wheel Polishing with Meguiar's Wheel Polishing Kit featuring the DynaCone.
    After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
    _________________
    Polishing your aluminum or chrome wheels can be a dirty, messy and often a time consuming job.
    And sometimes, simply choosing the correct polish to use can add confusion.
    To solve these challenges we've introduced Meguiar's Brilliant Solutions Wheel Polishing Kit.
    This kit eliminates the effort and confusion while creating a mirror like shine quickly and easily on all uncoated, polished or chrome surfaces.
    Start by washing and drying your wheels thoroughly to remove all loose debris.
    Attach the Meguiar's DynaCone Polishing Tool to any drill.
    Apply a small amount of the included Meguiar's All Metal Polish directly to the DynaCone Polishing Tool.
    Begin polishing with a slow speed, and gently work the polish on the surface.
    The unique DynaCone shape allows you to easily work on many different shapes and angles.
    Continue polishing and reapply All Metal Polish as needed for maximum shine.
    Remove any remaining residue using a clean microfiber towel to reveal mirror like results.
    Now that your wheels are like new again, it's time to clean and store your DynaCone Polishing Tool so it's ready for the next use.
    Simply remove the DynaCone Polishing Tool from the drill.
    Apply approximately 1 ounce of the supplied Meguiar's Foam Pad Cleaner directly to the tool, saturating the foam as evenly as possible.
    Submerge the tool in a bucket with approximately 1 gallon of water.
    Begin squeezing and kneading the foam thoroughly to release the oxidation and grime.
    Repeat this process several times until the foam looks like new.
    Finish by rinsing and squeezing the foam with fresh, clean water.
    Towel dry and store in a clean safe cabinet or drawer for the next use.
    Quick and easy wheel polishing each and every time using the Meguiar's Wheel Polishing Kit
    Registered Member Tafner's Avatar
    Jan 2011
    Rio de Janeiro, Brasil
    37
    202
    12
    Re: Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing
    That´s great!
    I was wondering if it would be ok to wash the wheels using the Dynacone prior to polishing.
    21,402
    1138
    Wash with the DynaCone? No. Best to stay with either an approriate wheel brush or wash mitt and the appropriate cleaning solution for washing prior to polishing.
    Registered Member Mark58's Avatar
    Mar 2011
    Erie PA
    72
    650
    15
    And what is best product to seal or wax to protect the wheels?
    Jan 2011
    37
    202
    12
    Thanks Michael, didn't want to sound like a noob but it seemed like a good ideia to get rid of some of that gunk before polishing. Now I know better!
    thanks a lot!
    Registered Member _Rodrigo's Avatar
    Nov 2010
    São Paulo Brazil
    42
    121
    will this Meguiar's Foam Pad Cleaner available to buy separately?
    I love car care lancergts2011's Avatar
    May 2011
    San Diego, California
    32
    9
    I have 18 inch alloy wheels that are on my new 2011 Mitsubishi Lancer GTS. What is the best way for me to keep them looking great. The vehicle is garaged so I have just been wiping them down every night with a cloth rag and I use a wheel and tire cleaner on them when I wash the car.
    39
    19,127
    237
    You'll want to at least be using a QD spray, not a dry rag.
    Are they clear coated alloys, or bare metal?
    Jun 2014
    South Florida, USA
    41
    6
    Drill speeds vary. What is the recommended RPM range for the Dynacone?
    21,402
    1138
    Quote Originally Posted by ErnestHouse View Post
    For most typical corded drills you can run them wide open for heavy correction. Obviously you'll want to feather the trigger a bit when you first start to avoid slinging the product everywhere, but once it's worked into the foam a bit, running at full speed is usually the way to go. Unfortunately, it's extremely rare to find a drill with actual RPM settings on it so it's darn near impossible for us to state "use XXXX RPM for this polish, XXX1 RPM for another".
  1. Meguiar's Quik Tips Video Series - Claying
    By Michael Stoops in forum Meguiar's Videos
    Last Post: Jul 25th, 2019, 12:54 PM
  2. Old article from 1994
    By alkemyst in forum The Break Room
    Last Post: Mar 18th, 2008, 03:01 PM
  3. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
  4. Questions about #7 Glaze and GC Wax
    By rdv350 in forum Detailing 101
    Last Post: Jul 5th, 2005, 08:50 AM
