Share your results with the Meguiars DA Microfiber System
  • Share your results with the Meguiars DA Microfiber System
    Is it the deepest reflection!?....
    Re: Share your results with the Meguiars DA Microfiber System
    It is a flexible and very capable way to correct all types of finishes with a low risk factor, throw in the low dusting and nice fragrance(cinnamon) and it is a win.
    As much as I use D300 on all types of jobs I find my self liking D301 more and more for the look, slickness and not too bad durability. For door jambs and painted areas of the underside of the hood it is a time saver to say the least......great job Megs!.
    "Comfortable in my own skin"
      Yes the new MF D/A system does create some nice reflections.
      Here is a reflection shot I took after using it on my F-150 a few months ago.
      Brian
        Nice!
        Here is my 200,000 mile 2000 Explorer after D300:
        Here is the other side of my garage...
        2007 Toyota Camry XLE
          Wow, this thread was started April 19 and it took 2.5 months for someone to post a reply. Crazy.
          Colin
            Better late than never...
              I love the D301.
              Such a nice product. Easy to apply/remove, looks great, and has good durability.
              Been using it as my LSP ever since it has been released, hardly been using anything else.
                is there a need to apply m21 after the DAMF system?
                  You do not "need" to, but you can if you like.
                  Brian
                    Couldn't be happier. System works great. Very fast. Clean pads after every section with compressed air or tool. Every time I wiped product off, I cleaned pad. Seems labor intensive but it's not and definitely worth it. Used speed 4 with light to moderate pressure.
                    [IMG][/IMG]
                      1993 Honda Civic, never been detailed. Went over the area with a clay bar and then the DA MF. Really brought out the paint with only couple passes.
                        Great results!!!!!!
                        http://www.youtube.com/watch?v=vTjNLkxalcM
                          These are some great reflection shots guys! Keep them coming!
                            D300/ D301/ UPW/ G110v2:
                              Early 2000 black ranger.
                              D151 MFC test spot. Left 4 hard passes right 4 really hard passes
                              D300 MFC 4 passes same truck
                              I really like the cutting pads will post more pics when done.
