test spot has me worried
Results 1 to 6 of 6
Thread: test spot has me worried
    QuicknClean
    Jun 2009
    Gainesville FL
    15
    12
    95 avus m3, i doubt this car has ever had a real paint correction. Never garaged, california and florida sun. Im planning a "2 stage" compound and polish job next weekend, the other day i did a test spot by hand on the worst area of my car. My drivers door already looks oxidized so i used some megs UC/swirlX on a small squared off section. The section if anything, looks worse. Heres a photo I took today with the car not clean. Theres no paint on the pads, but im nervous i guess that the coat could be too thin to correct. Just looking for help from those with experience. Thanks!
    QuicknClean
    Jun 2009
    Gainesville FL
    15
    12
    Re: test spot has me worried
    to update this, i can probably attribute this too my watery UC. I think all that did was make it worse. Ill pick up some new UC and see how it goes this weekend.
    Apr 2011
    United States of America
    4
    did you apply it by hand? DA?
    what pads did you use?
    how long did you work the products?
    40
    19,233
    239
    Which side of the pic is the test spot?
    QuicknClean
    Jun 2009
    Gainesville FL
    15
    12
    test spot by hand
    the lighter area was the test. The darker area is the tape line.
    Dec 2009
    Iowa
    2,636
    40
    I wouldn't think watery Ultimate Compound would make the finish worse.
    So I'll repeat Murr's and icare's questions:
    Is the "done" side of your photo the right or left?
    What were you using for a pad or applicator? Foam or microfiber?
    How long did you work the product(s)? You mention UC and SwirlX, did you use both?
    Also did you shake the bottle thoroughly? I would think only frozen or a really old bottle of UC would be watery.
    Thanks for the additional information
    David
  1. First time Using M105 and M205 (test spot only)
    By Ravi_1992 in forum Show Off Your Latest Detail Work
    Last Post: Jul 23rd, 2010, 08:23 PM
  2. The Reverse Test Spot
    By Mike Phillips in forum Tricks of the Trade!
    Last Post: Dec 15th, 2009, 12:33 PM
  3. The Cruel Test Spot - This or that? - Reverse Bait & Switch
    By Mike Phillips in forum Detailing 4 Dollars
    Last Post: Dec 11th, 2009, 04:07 PM
  4. Test Spot on Client's car
    By Clutch34 in forum Detailing 101
    Last Post: Nov 18th, 2009, 09:48 AM
  5. Replies: 24
    Last Post: Sep 21st, 2008, 02:22 PM
