Thanks OtherPC. So my brain is tired now. Do the specs indicate that it would be accurate enough for me to differentiate between .1 and .5 Mil? It seems that it would since a micron is smaller than a mil.
Richard Lin
ShowCarDetailing
5548 E. La Palma Ave
Anaheim, CA 92807
toll free: 866 707 9292
Ok, after doing a bit more reading and research, I bit the bullet and ordered one. It's being shipped from China. To avoid the commercial links rule, go to eBay and search for item # 230003105642
Price was $164 + shipping International FedEx, total came out to $188.98
I saw the ETG-A on eBay was selling for close to $600 from a dealer today.
Richard Lin
ShowCarDetailing
Anaheim, CA 92807
I got an email from FedEx last night and an email from the vendor today. Says the item has been shipped and will arrive Wed by 10:30AM. That means I'll bring it to the Wednesday Garage Clinic. Anyone that wants to check it out, come to the clinic! Mike and I will compare it to the unit that Meguiar's owns.
Richard
Richard Lin
ShowCarDetailing
Anaheim, CA 92807
Well after much headaches with FedEx, I finally just went down to the FedEx station and picked up my package, since they had such a hard time delivering it to me.
The wait was worth it.
I put in 4 AA batteries, plugged in the probe, and started taking measurements on my MINI. On the bonnet (hood), it was measuring around 4.5 to 5.5 Mil on the flat surfaces, and up to 7Mil on the top of the curviest parts.
There is a switch to change from Mil to um. Also included were some metals for calibration.
I then took the probe to my test panel, which is the rear hatch off a MINI. I took some test readings there and was getting 7Mil. Then I put the probe on a rotary buffer "hole" that I created a year ago--bare metal. It read as expected 0.3 or almost 0. I moved the probe to the surrounding area and it read 4 Mil.
The instructions say it wll read any non magnetic surface--plastic or paint on a magnetic surface--so it works on anything that a magnet will stick too. Sorry no Fiberglass here.
I tried it on the spoiler of my MINI and no reading. I also tried on some plastic painted panels and no reading. But it worked fine anywhere else.
Now I'd like to compare it to the ETG-A or similar unit to see whether we get similar readings or not.
So far so good. The price was right, shipping was fast, and it's easy to use. More tests coming.
Richard Lin
ShowCarDetailing
Anaheim, CA 92807
Thanks to Octane Guy, I also ordered one of these. It's fine...I even found out my trunk and hood are aluminum Super-fast shipping from the other side of the world. My only problem is it very shortly stopped beeping when taking readings. The speaker still works, because it beeps when you power it up, but it initially beeped as it registered each reading (same as a more expensive unit I borrowed from work), and it doesn't now.
I don't recall mine ever beeping but I did have trouble getting it to take a reading yesterday. Reset didn't solve it, but unplugging probe and plugging back in did.
Richard
Richard Lin
ShowCarDetailing
Anaheim, CA 92807
Originally posted by OctaneGuy You get what you pay for. I wanted a part time use tool that was accurate.
I think the thing is great. Only problem is support and service is likely to be non-existant. Based on what I've seen so far, though, this instrument seems to stand up in the important measures of quality (read: accuracy) to other instruments.
How much clear do you think would be removed using M03, Machine Glaze, about every couple of months? I've been told that M03 is the least aggressive polish. My finish is in excellent condition; I just want to step up the look of the vehicle. Thanks.
