Gonna give it a try for sure next time.
But the MF finishing disc would still be used with 205, wouldn't it ?
How to know when to choose between the MF finishing disc and the W9207 Foam Finishing Pad ?
I guess one would use the foam pad just when no cut was needed, i'm I right ?
You would use the M205 with your normal foam pad, as was intended.
You could experiment however and try M205 on an MF pad. I'm sure it would be fine - it would just give you a little more cut (but consequently, less clarity). I think anyway - try it and let us know!
What a fantastic job! First time using a DA and this DA MF System..that's amazing!
This shows how things are changing....
Hi Yalerd, thanks for the comments, things are really changing but I believe for the better! The novices like me need training and MOL is the place for that!
