G110v2 and G220v2
Results 1 to 7 of 7
Thread: G110v2 and G220v2
    Dec 2007
    79
    12
    G110v2 and G220v2
    Previously i reviewed that G110v2 was the best machine that i've ever used. It didn't bogged down even with speed setting 1 or 3 or 5. After several applications with Meguiars Polish & Finishing pad, it feels like v1 all over again, occasional rotational action stop and the pad feels heavy/dragged along.
    My friend just bought the new G220v2 and tried it out as comparison. Came to a surprise that G220v2 had a soft start like rotary and felt more powerful.
    Theory #1: I live in 220v environment, so i figured gotta be the transformer that change the 220v input into 110v output that caused the problem.
    Theory #2: My pads are slightly curved, so the non-flatness might cause the problem.
    So i tried to disprove my theory by using my cuved pads on his 220v2 machine, it rotated like normal, unlike in mine which bogged down a lot. So my question: Is there any design improvement on G220v2, specifically the soft start? I bought my G110v2 about March/April 2010, so it's not that long ago.
    Also regarding the Meguiars pad: I switched to a brand new flat Meguiars pad, and the problem disappeared as well. It made me to turn into Lake Country 5.5" pad cause it's much more manageable and the pressure is more even to the pad due to smaller gap between the pad and 5" Backing Plate. The difference between 7" pad and 5.5" pad are night and day, i can finally make my D/A to feel like a mini rotary once more. So here comes question #2: Does anyone experiencing the same thing? I used the pad about 4-5 cars since my first purchase and they already bogged down the machine.
    Thx
    Dec 2007
    79
    12
    Re: G110v2 and G220v2
    Friendly bump....anyone?
    Mar 2011
    Bahrain, Persian Gulf
    45
    9
    I am curios to knwo too, because I have placed my order today for the G220v2 from UK.
    2011 Maxima Satin White Pearl QX3
    2012 Renault Clio RS200 Liquid Yellow
    Meguiars G220 v2 DA Poliser
    Registered Member Mark58's Avatar
    Mar 2011
    Erie PA
    72
    650
    15
    My first question would be is what are the specifications on your step down transformer? What voltage do you have? 220? 210? need to measure. First guess woud be that you might be somewhat low on voltage after stepping it down or under load.You would actually need to measure voltage at your cord under load.
    Registered Member FRS's Avatar
    May 2010
    Sydney, Australia
    620
    16
    I'm using the G220 here
    in Australia. 7" pads are too big for this machine that lacks power imo.
    4" pads are ok.
    i just ordered the Flex 3401, G220 will end up on ebay.
    Registered Member Ultraman's Avatar
    Mar 2009
    Quezon City Philippines
    75
    I'm using a G110v2 with a step down transformer, since I live in an 220V environment. The G110v2 works perfectly! Very powerful motor even when using 8" pads.
    Greetings from the Montero Sport Club of the Philippines! Visit us online at: www.monterosportclubphils.com
    Mar 2011
    Erie PA
    72
    650
    15
    I still think that it's his step down transformer. It just might be to small and the voltage drops while putting the polisher under load. Need to run it under load and check voltage.
  1. Dual Action Polisher G110v2
    By Michael Stoops in forum Machines - The Dual Action Polisher
    Last Post: Aug 1st, 2011, 08:46 AM
  2. G110v2 vs G220v1 vs UDMv1
    By nothelle in forum Machines - The Dual Action Polisher
    Last Post: Jun 27th, 2010, 10:26 PM
  3. UK USER - G110v2?? G220v2??
    By mk2r32 in forum Machines - The Dual Action Polisher
    Last Post: Jun 13th, 2010, 10:57 PM
