I'm in the minority here I'm sure.
I have a pump dispenser on all of my Detailer containers. I happened to pull a couple out today to refill spray bottles and noticed liquid all over the shelf underneath everything. Apparently the plastic tube from the pump managed to push through/puncture the plastic of the container causing a slow leak. I've apparently lost almost 1/2 gallon of my APC which is a real drag because I've only filled those spray bottles up once or twice. Never noticed it because there's another container in front of the APC and it all ran to the back of the shelf and then down the back wall behind all of my detailing supplies.
Anyone else had this happen? Seems to be a bit weak plastic if the pump straw/tube managed to poke a hole through it just sitting on a shelf.
