Wetsanding fresh clear coat
Results 1 to 5 of 5
Thread: Wetsanding fresh clear coat
    Jun 2008
    US
    7
    12
    I am working on spraying the rear fenders of my '53 chevy. I'm spraying it myself in my garage so needless to say there are a few dust nibs and flaws in the finished product. I am planning on wetsanding the fenders with 2000 grit to knock back the dust nibs but I'm not going to go nuts on the orange peel. Is that a good grit or should I go finer?
    I have a rotary and M105 already but I need a new pad(s). Is there a recommended pad for correcting 2000 grit scratches in fresh clear? I can't image it would be all that hard if I work on it a couple days after I spray it.
    Also, is it necessary to follow the 105 with 205? If so, is there a recommended pad for that? I've been reading threads for hours, and its getting very confusing.
    Thanks!
    Registered Member Mark58's Avatar
    Mar 2011
    Erie PA
    72
    650
    15
    Re: Wetsanding fresh clear coat
    I would check with your paint supplier to see how long you need to wait before wet sanding or any paint correction. With some Clear coats you need to wait 30 days or longer.
    Jun 2008
    US
    7
    12
    Quote Originally Posted by Mark58 View Post
    The spec sheet for the clear coat says it has an 8 hour dry time before it can be sanded with 1500 or finer.
    Mar 2011
    Erie PA
    72
    650
    15
    In that case try a test panel. if you are using 105 I would use Yellow cutting pad and for 205 for polishing I would use Blue. Now that's only my opinion.
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    66
    You could also refine the sanding with 3000 grit paper. It would make it easier to remove sanding marks saving time while buffing out.
    M105 with either wool (like Meguiar's W4000 or W5000 double sided) or foam cutting pad and a rotary buffer would work best to remove the sanding marks.
    Then M205 with yellow polishing pad as swirl removal and M205 again with black finishing pad for gloss restoration would be a good follow up.
    Also Meguiar's So1o System is designed to work on fresh paint with just one liquid (M86 Cut & Polish Cream) and wool/ foam cutting/ polishing pads:
    http://www.meguiars.com/solo/products.cfm
  1. Need Help! Paint Removal, Over Clear Coat.
    By Paint-Shield.ca in forum Detailing 101
    Last Post: May 18th, 2010, 02:22 PM
  2. How to test for a clear coat or single stage paint system
    Last Post: Aug 27th, 2008, 06:53 AM
  3. Starting from "Newly Sprayed" Clear Coat
    By Cue Caps in forum Detailing 101
    Last Post: Jun 16th, 2008, 04:56 PM
  4. Clear Coat + Dead Paint
    By OSP in forum Detailing 101
    Last Post: Jun 2nd, 2008, 11:34 AM
  5. Clear coat vs Non-Clear coat
    By Vriesea in forum Detailing 101
    Last Post: Aug 16th, 2006, 10:40 AM
