D300/M105 by hand?
Results 1 to 5 of 5
Thread: D300/M105 by hand?
    Mar 2011
    Downers Grove IL
    12
    D300/M105 by hand?
    My PC7424 pads are too big. Is D300 or M105 as affective by hand application on my motorcycle?
    21,405
    1140
    Re: D300/M105 by hand?
    M105 can work very well by hand in tighter areas, just start easily and work up on the pressure as needed. You can usually finish out really nicely too by easing way up on the pressure as the product thins out. D300 can be used by hand too, but it won't offer as much cut as M105 - which might actually be a good thing, depending on what you're trying to get out. D301 is a great follow up, again via hand application, to remove any light hazing you might get from either M105 or D300.
    A great way to apply D300/D301 by hand is with the 3" microfiber discs affixed to an S3HP hand pad.
    Aug 2004
    Glendale, AZ
    37
    2,962
    52
    Mike, is the S3HP the same ones that come with the heavy duty headlight restoration kit?
    21,405
    1140
    Same concept, but the S3HP is a much more robust piece designed to stand up to constant use. Both will accept 3" sanding/finishing discs, 3" microfiber discs as well as the 4" Soft Buff foam pads.
    Oct 2008
    SC
    88
    I use both on my hood around the washer nozzles and a few other places where pads can't get enough cut or it's too tight and it finishes out pretty well. Microfiber or terry applicator or a finger in a microfiber towel with a light spray of QD and just a little D300 or M105.
  1. Replies: 22
    Last Post: Dec 25th, 2009, 01:07 PM
  2. removing scratches by hand
    By Daniel Kinder in forum Working by Hand
    Last Post: Nov 19th, 2008, 01:50 AM
  3. M105 by hand review.
    By jmakado in forum Professional Line - Product Reviews
    Last Post: Jul 21st, 2008, 11:10 AM
  4. Hand applicator tool
    By jpitt1987 in forum Detailing 101
    Last Post: Jul 18th, 2008, 03:39 PM
  5. Dual Action Polisher or By Hand?????
    By C5-Deb in forum Detailing 101
    Last Post: Mar 31st, 2004, 08:05 AM
