Hi all, I'm new to the forum. Here's my problem: I was trying to remove some small clear coat scratches with some 3M Wetordry 2000 grit sandpaper and soapy water. I was lightly rubbing the sandpaper on the bumper and I finished so I wiped the water and everything off. I'm left with this dull spot on the bumper where there is no shine.
I used Meguiar's Ultimate Compound to try to get rid of the dull spot and it doesn't help the spot out . I've attached some pictures FYI. I don't know a ton about paint and I was hoping that someone here would know what to do to get rid of the dull spot. I know for a fact that I did not go through the clear coat. I have a buffer, but it's a cheapo. Someone told me that the orange peel would most likely be gone also. So my question is: What can I do to fix this? Thank You
*Images far, far too large*
