is there such thing as leaving wax on too long?
Results 1 to 7 of 7
Thread: is there such thing as leaving wax on too long?
    May 2011
    new york
    140
    12
    I was waxing my car (2011 mazda 3 hatchback) yesterday when i noticed as always the Tech 2.0 wax i was using did take a long time for the SWIPE TEST to work. It would always smudge even after half hour...
    so I left it on for almost 3 hours! (it was around 73 degrees outside and not too humid)
    i noticed that it really hardened a lot and took more work to take off...it would also "flake" into dry particles (the car had been waxed once before, was it because I was taking off the last layer of wax before this?
    Because I noticed that when I waxed the rear bumper (I haven’t waxed this part of the car before, it went on EASY…PASSED the swipe test in only 20 minutes and came of clean without “flaking”)
    Although the bumper is "plastic" with clearcoat black finish, is it easier to wipe off on plastic surfaces? but it should be the same because it's the same paint and clearcoat as on metal surface
    Did I leave the wax on for too long??
    Registered Member Carolina08's Avatar
    May 2011
    Lexington, South Carolina
    31
    83
    Re: is there such thing as leaving wax on too long?
    Yeah, unfortunately it sounds like you waited way to long. Your prior layer of wax was probably gone anyway, so it's definitely not that. Next time, I would say leave the wax on for the whole duration of waxing the car and that should be more than enough. Also, try to apply a thinner layer, there may have been too much. Sometimes I do one panel, and have to wipe it off before the whole car is done.
    Did you do this in the sun or the shade? Maybe you were applying the wax to thick? Sometimes that can also have an impact on how the wax takes to your vehicle, and you always want to be sure to be in a shady area.
    21,405
    1141
    Time and humidity play a role here, as does thickness of application.
    Usually, with a properly thin application (and most people tend to way over use wax) NXT 2.0 should be dry in 15 - 30 minutes, depending on humidity. A thicker application will take longer to dry, higher humidity will also extend drying time.
    Here in dry SoCal, with a very thin application, we know of several people who've left NXT 2.0 on the paint for 2 to 6 hours and wipe off was a breeze. But we also know that it was applied very, very thin. In New York you're bound to have higher humidity, and a prolonged dry time will start to draw moisture out of the air and into the hazed product, making wipe off less easy..... or even flat out difficult. Again, how thick or thin it's applied will impact this.
    You really only need an ounce of product to cover a full sized car. We used barely over half an ounce to cover a 2002 Camaro last fall at a Thursday Night Open Garage, just to prove the point.
    May 2011
    new york
    140
    12
    thanks for the reply!
    but the thing is, even after an hour and a half, it didn't pass the swipe test...it would smudge instead of coming off clean...so i wasn't sure if it was ready to be wiped
    Not for Money Detailer k3ith's Avatar
    Nov 2009
    Memphis TN
    281
    15
    Quote Originally Posted by brendan1234 View Post
    Do you have greasy fingers? Just kidding. I hardly ever get the swipe test to work well with synthetics. Don't worry so much about it "being ready". Even if you begin removal immediately after you apply to the whole car, your still going to get good appearance and protection. With NXT 2.0 I usually wait about 20-30 after full application and remove regardless of what I find in the swipe test.
    Also, as everyone has said here, the likely problem you had was putting it on too thick. I suffer from too thick waxing syndrome myself, which is likely why swipe test doesn't work well for me.
    "The Dude Abides"
    Registered Member Mark58's Avatar
    Mar 2011
    Erie PA
    74
    649
    17
    Sounds like you applied it little to heavy.
    my 2 cents
    Oct 2009
    In the office
    697
    19
    I am a heavy handed waxer and for me using a cheap orbital wax spreader has helped a great deal. I will mention comparing NXT 2.0 and Ult. Wax is that Ult. wax for the most part comes off easier. I still have a nearly new bottle of liquid 2.0 so I will have to use it but something to think about.
  1. Paint Evaluation and Product Selection
    By Kevin Doe in forum Detailing 101
    Last Post: Dec 26th, 2006, 10:45 PM
  2. Importants Questions need to be answered??
    By aref in forum Detailing 101
    Last Post: Oct 26th, 2006, 06:22 PM
  3. G-100 is here!
    By TSR6 in forum Machines - The Dual Action Polisher
    Last Post: Jun 9th, 2006, 06:41 PM
  4. Another newbie mistake
    By JagLover in forum Detailing 101
    Last Post: Jun 8th, 2006, 04:12 PM
  5. 3000 grit... use #83?
    By integraoligist in forum Detailing 101
    Last Post: Jun 3rd, 2005, 11:08 AM
