sorry no pics. got a call this morning and i will be working on it friday. he made it sound like it was in pretty good condition, but that may not be the case...thanks for the info!
i can use regular auto wax for this correct? i was thinking about using nxt 2.0...would this be fine???
thanks
All fiberglass is not equal. Is it gelcoat alone? painted? clearcoated? If it's not painted and or clearcoated you can bet it has some oxidation and wax alone will make little if no improvement at all. In fact, applying just wax to oxidized fiberglass can leave a splotchy uneven result. You'll need the oxidation remover for starters and a wax after that more likely.
are fiberglass travel trailers gel coated?? i am curious because i bought some meguiars wax for the gel coat boat i was working on and am curious if i can use it also on this travel trailer...it says rv/boat on the bottle??
