Ultimate compound + Clear Coat (burn through??)
Results 1 to 5 of 5
Thread: Ultimate compound + Clear Coat (burn through??)
    Jul 2011
    singapore
    5
    9
    Was using the UC to try to blend the touch up paint with the surrounding...as i hand rub it more..the touch up paint blend in better..but it created this circular shape around it which i can't get rid off...tried using autoglym super reisin polish also can't get rid of it. I was worried it might be clear coat burnt through...but i din see any pick up of paint.
    I use a microfiber cloth then with the UC to do the work....ANyway i can restore this?( Seriously hope it is not a burn through ) Shld i get swirl X to help or can i use glaze or anything from Meg to improve? my ride is a 3mth old audi A4
    Registered Member J4o2el7's Avatar
    May 2011
    Tacoma Washington
    155
    Re: Ultimate compound + Clear Coat (burn through??)
    Was the whole panel re-sprayed? Or just spots? how long did you let it cure before going at it?
    Jul 2011
    singapore
    5
    9
    there was some respray there abt a month ago...and the respray wet sanding not done properly...as for my touch up paint..it set for a day before i started doing this.
    The ring is not the area with the touch up paint. in fact if u stare hard enough, you can see a small bump at the center. that is where the touch up is.
    i check my white pad applicator. it is not picking up any black paint.
    Registered Member THE BIG BUFFER's Avatar
    Jul 2006
    347
    17
    Quote Originally Posted by ock View Post
    .........my ride is a 3mth old audi A4
    Were you in an accident? Just curious as to why a 3 month old car need this work done. Looks to me as it is burn but maybe not all the way threw the clear..yet.
    Professional Automotive Reconditioning Services
    "You scuff it-I buff it!"
    Jul 2011
    singapore
    5
    9
    sort of. if is not all the way through clear..can i still fix this?
  1. Used polish compound on clear coat
    By boatuser41 in forum Detailing 101
    Last Post: Jul 27th, 2012, 08:07 PM
  2. Replies: 4
    Last Post: Oct 21st, 2008, 09:19 AM
  3. Clear coat burn
    By milkman in forum Detailing 101
    Last Post: Aug 19th, 2008, 07:49 AM
  4. anti burn clear coat
    By PAPPAJUSTIFY in forum Meguiar's Consumer Line Products
    Last Post: Mar 28th, 2008, 08:03 AM
  5. Replies: 2
    Last Post: Feb 28th, 2008, 08:18 PM
