Difference between QUIK DETAILER and ULTIMATE QUIK DETAILER? And how to use it?
Results 1 to 9 of 9
Thread: Difference between QUIK DETAILER and ULTIMATE QUIK DETAILER? And how to use it?
    Mar 2010
    WV
    12
    Quik Detailer (whatever comes with the claybar kit)
    and Ultimate Quik Detailer.
    What is the difference?
    Basically My truck has some light dirt on it from rain an ddriving on the road. I use Quik Detailer (again im using the stuff that comes in the claybar kit) and i just spray on the truck and whip it off. Is this its the intended use?
    If im doing this wrong please tell me so i can stop. This just saves be from washing the entire truck every other day
    40
    19,215
    238
    Re: Difference between QUIK DETAILER and ULTIMATE QUIK DETAILER? And how to use it?
    Either is ok for light dust.... the question is always what is light dust. But you should watch for any swirls caused, and if you dont see any, then you are doing well.
    The QD is basically just a gentle cleaner.
    The UQD is a gentle cleaner that also leaves a polymer coating behind, so a little protection. So should make the next dirt wipe off easier also.
    If you are using a lot of a spray detailer product, you really should look at buying in bulk, with something like Final Inspection (QD), or #135 Synthetic Spray Detailer (UQD).
    Aug 2004
    Glendale, AZ
    36
    2,962
    52
    UQD also has the hydrophobic polymer technology so it repels water like crazy! The standard QD does not have this.
    May 2004
    1,107
    28
    Quote Originally Posted by Marc08EX View Post
    I use both UQW and UQD.
    Not see much difference after either product......
    Aug 2004
    Glendale, AZ
    36
    2,962
    52
    Quote Originally Posted by mis3 View Post
    We were comparing UQD and the standard QD.
    Anyway, to answer your question: their intended purpose is different. UQW is intended to apply to a clean surface. It's also used to leave behind some wax protection or boost your current layer of wax. UQD is intended to remove dust particles, smudges or even bird droppings. Although UQD leaves behind some polymer coating, it's probably not as strong as what UQW leaves behind.
    Registered Member ethereal45's Avatar
    May 2011
    Nebraska
    471
    14
    How does Last Touch compare to the other quick detailers (QD, UQD, Final Inspection, etc)?
    Aug 2011
    Bangkok, Thailand
    Can I use the UQD for removing fresh tree saps or other sticky residues off the paint, or should I consider other products or just regular QD?
    May 2004
    1,107
    28
    Quote Originally Posted by IS2000 View Post
    This is exactly how I use my UQD; tree sap, bird droppings, road tar, etc.
    Also, I leave a bottle of tap water in the trunk to "soften" the sticky residues before applying the UQD.
    40
    19,215
    238
    Certainly the thing to try first, as it is mildest.
  1. Ultimate Quik Detailer or Quik Detailer?(Clay lube)
    By kikemtz in forum Detailing 101
    Last Post: Aug 2nd, 2016, 07:15 PM
  2. Quik Detailer the same as Ultimate Quik Detailer ?
    By Eddystone in forum Detailing 101
    Last Post: Oct 4th, 2010, 05:35 PM
  3. quik detailer and ultimate quik detailer
    By bigworm36 in forum Detailing 101
    Last Post: Feb 8th, 2009, 09:02 AM
  4. Replies: 6
    Last Post: Aug 21st, 2006, 10:04 AM
  5. Replies: 7
    Last Post: Feb 5th, 2005, 09:20 PM
