Chrysler specific headlight hints/tips
Results 1 to 9 of 9
Thread: Chrysler specific headlight hints/tips
    Off Road Racer DEZERTSUB's Avatar
    May 2011
    Lake Elsinore, CA
    17
    9
    I've been having difficulty removing the clear protective coating from Chrysler/Jeep vehicles, which is the main reason any Chrysler vehicle has crappy looking headlamps. Working on a PT Cruiser right now, and getting the lens itself immaculate is cake (Using Meguiars Heavy Duty Headlight kit), it's getting the old protective coating off that's getting to me. Would using a strong solvent like acetone help me get that stuff off without damaging the integrity of the plastic that is the headlamp lens? Been going after it with 600 wetsand, and it's working, but it's just taking too long. Tempted to try lighter fluid, acetone, mineral spirits, even paint stripper (but can't screw up this customer vehicle). Curious to see if anyone else has any solutions for this to make the process simpler and faster.
    If no one chimes in, on my next trip to the junkyard I'm gonna buy several old Chrysler headlights and try different things until I can determine what works the best with no damage to the lens. Yes, I will share my results.
    Innovative Detailing Innovative Detailing's Avatar
    Oct 2009
    Orange County California & LHC Arizona
    291
    43
    Re: Chrysler specific headlight hints/tips
    My advise is to stay away from the "Chems"......they will do your customers lenses more damage than good.
    What you need to do is take your level of resurfacing disc's down using the following Meguiar's "Unigrit" grades.....you need more bite in your initial cut to level off that failed OEM UV coating.
    320>500>800>1000>3000 then polish or recoat.
    May 2011
    Lake Elsinore, CA
    17
    9
    You want me to sand a headlight with 320????
    Yeah, right.
    David, did you not see the last paragraph of my post? I'm gonna try some different chemicals on throw away lenses. You know, I'm gonna be "innovative" and look for new solutions and other viable options.
    Registered Member juliom2's Avatar
    Aug 2010
    Puerto Rico
    274
    12
    Exclamation Re: Chrysler specific headlight hints/tips
    Go for the 320........!!!!!!!!!!!!!!! And of course the rest to follow...........
    You will be amaized with David's innovative technique......
    Good luck, have fun............
    Oct 2009
    291
    43
    Thats how its done.....start off with 500 first....if it doesnt cut it then drop down a grade.
    Good luck in your attemps....been doing this for years now and I have restored over 500 sets. IMO there is only one way to do this type of service in which you get results that look as clear as a CD case when your done.
    Invest in a Meguiar's Professional Headlight Repair Kit and you cant go wrong........everything you need (Except the compressor) to get the job done right the first time. Then if you decide to recoat down the road you have that option to offer this.
    Here is a PT we recently did.....
    Started off with 320
    Finished off with 3000
    Recoated
    BTW if you think these are a tough coating, wait till you get your hands on a set of 996 lenses......tough as nails!
    Is this real life? JoeDirt's Avatar
    Jul 2009
    Grand Rapids, MI
    421
    18
    Agreed- why would you so easily disregard the advice of someone that does it for a living?
    2007 Toyota Camry XLE
    Registered Member Jumper09's Avatar
    Jul 2010
    Michigan
    47
    I also had the same problem with the PT Cruiser. I did one last year about this time and I started with 800 but had to drop to 400 to get the level of cut I needed. after that, the rest was a breeze. I also noticed, This is my aunts car, that this year some of the yellow has come back. I don't know if this was my fault by not putting on enough sealer or what but now I have to touch them up again. Just something for you guys to look out for. I have also notice that some of the other cars I've done are still clear after about a year and a half. Thanks.
    21,402
    1138
    Quote Originally Posted by DEZERTSUB View Post
    Yeah, right.
    Yes, totally and completely right. Don't be so quick to dismiss the advice of a seasoned pro like David. Our Professional Headlight & Spot Repair Kit comes with 320 grit sanding discs, specifically for use on headlights when they're really bad. Have a look at this thread for proper use of the kit and sanding headlights in general.
    We're with David on this, too. Any solvent that's going to be potent enough to remove the coating is likely going to be potent enough to damage the lenses, too. Plus, it's going to be a lot messier than sanding and, well, we'd hate to see what a solvent strong enough to remove that protective coating might do to the surrounding paint should any get on it. Besides, why go out and buy a bunch of unproven chemicals, dig through a junk yard pulling lenses, etc when there's a solid, proven, repeatable process right at your fingertips? We're all for experimenting, but sometimes it's not worth the time, effort and energy.
    Apr 2015
    canada ontario
    6
    5
    Yeah, right.
    the entire purpose of sanding is to remove defects.... the lenses are super thick 320 wont hurt anything
    im super new to this and to so quickly dismiss someones advice and insist on using chemicals that can leach into the plastic is not smart thinking. to each his own though
  1. Meguiar's Quik Tips Video - Consumer Headlight Restoration Kit
    By Michael Stoops in forum Meguiar's Videos
    Last Post: Sep 10th, 2013, 06:55 AM
  2. Hints & Tips On How To Repair Rock Chips.
    By rapport25 in forum Detailing 101
    Last Post: Mar 16th, 2011, 07:30 AM
  3. Hints and Tips On Detailing A Honda?
    Last Post: Feb 5th, 2011, 03:04 AM
  4. Hints
    By Rico in forum Detailing 101
    Last Post: Nov 19th, 2010, 03:48 AM
  5. Spill....any hints of what it is and what can be done to fix
    By MotorcycleDetailing in forum Detailing 101
    Last Post: Mar 11th, 2007, 12:29 AM
