I want to pick up an air random orbital and a standard hook and loop backing plate, but I am a little uncertain about the style of hook and loop on the 6" foam interface. I have read that there are different styles, like micro, and I want to be sure that they are compatible. So onto my questions..
1. Would it be overkill to use the foam interface and a foam finishing disc or is this actually recommended?
2. Would it be essentially the same to use a foam interface w/ a sanding disc as using a foam finishing disc?
3. Would a foam interface cut down on the cutting ability of say a 1500 disc if removing orange peel was the target?
4. Will there be compatibility issues with the styles of hook and loop if I use a standard 6" backing plate > S6FI 6" foam interface > unigrit sanding discs or even 3m sanding discs?
Thanks
Thanks
