Live in canada winter is approaching and i as wondering if anyone has info on the lowest temps M/F correction system and maybe megs 105/205 with a GG6 DA will work? Between now and winter my garage will be aprox 6-20 degrees Celsius or (42-68 F) inside my garage during the day for a detail job. with humidity varying from 30 to 75%, again any info when and at what temps i may run into problems correcting paint?
Lowest temp M/F system will work and shelf life
Re: Lowest temp M/F system will work and shelf life
my experience is that everything works as normal above 10 degrees celsius, including wax application and everything.
It is the minimum temp i run in my garage in winter.
I keep a termostat guided heater in my product storage room, never goes below 10 degrees. My main concern is when the power goes outArctic Detailing - Northern Norway
1996´AUDI S6 AVANT QUATTRO
Originally posted by Joenok View Postmy experience is that everything works as normal above 10 degrees celsius, including wax application and everything.
I keep a termostat guided heater in my product storage room, never goes below 10 degrees. My main concern is when the power goes outMichael Stoops
