Ultimate Wash & Wax Anywhere - Page 4
Page 4 of 13 FirstFirst 123456789101112 ... LastLast
Results 31 to 40 of 130
Thread: Ultimate Wash & Wax Anywhere
  1. #31
    Registered Member 79elcamino's Avatar
    Aug 2009
    Brooklyn
    530
    16
    Re: Ultimate Wash & Wax Anywhere
    Well, just how cold a temp are you thinking about using it in? 5F might be problematic, but in a garage you can probably get away with it at very cold temps as long as you act quickly enough. But the sprayer isn't an atomizer or super fine sprayer so that alone should not pose an issue.
    around lets says 20F to 40F
  2. #32
    21,402
    1138
    Quote Originally Posted by CumminsCrazed View Post
    ok so, for my custom truck i have, what would be abetter choice for me after i get to car shows, i pre detai teh truck prior to the show, so would the no rinse express wash be better, or the quick wash n wax anywhere stuff.
    As PPLd pointed out, this ready to use spray would be the better choice in the application you've described.
    Quote Originally Posted by 79elcamino View Post
    That shouldn't be a problem especially considering that you'd be working small areas at a time anyway.
  3. #33
    Oct 2005
    48
    189
    16
    The Detailer line Rinse Free Express Wash is a concentrate designed for use as a low water volume rinseless bucket wash. Rinse Free Express Wash also contains no wax at all. Ultimate Wash & Wax Anywhere is a ready to use spray that does contain a hydrophobic polymer for added protection. Think of it almost like a detail spray on steroids - if you've ever had a situation where you thought a QD may not be quite enough to remove the amount of dirt on your car so you're better off washing it, you could reach for this product and get the job done safely and effectively. If you live in an area where they salt the roads and from time to time you go to the coin op wash to pressure wash the road salt off your car, you know it doesn't get everything off completely. With this you can finish the job once you get home. Or if you live in an apartment and it's summer time, and your car has been outside for a few days and you want to clean it up but don't have time to go to a car wash (and you aren't allowed to bucket wash in your complex) you can clean your car with this product in just a bit longer than it would take to go over it with a traditional QD spray, even though the car is much too dirty for a traditional QD.
    So if you are recommending a coin-op wash before using UW&WA. I take it that it can't cut dried salt crust? I am very interested in this product.
  4. #34
    Registered Member mike_svt's Avatar
    Jun 2004
    Burlington, VT
    234
    18
    Ultimate Wash & Wax Anywhere's unique chemistry insures a scratch-free finish when used as directed, as special lubricants and cleaning agents safely loosen and then gently remove the dirt.
    I ensure you I'll try this product, regardless of the typo in the description.
    1999 Ford Contour SVT
    Silver Frost/Midnite Blue
    1966/2760
  5. #35
    Dec 2009
    Iowa
    2,634
    40
    Mike's assurance is better than insurance.
    David
  6. #36
    Jun 2004
    Burlington, VT
    234
    18
    Quote Originally Posted by wifpd4 View Post
    Too bad you couldn't put that in a 16 oz. spray bottle
    1966/2760
  7. #37
    Dec 2009
    Iowa
    2,634
    40
    Quote Originally Posted by mike_svt View Post
    Too powerful, only available in 8 oz. sample size.
    David
  8. #38
    Detailing Dunce akimel's Avatar
    May 2008
    Roanoke, Virginia
    2,378
    149
    I'm looking forward to this product. For the past two or three winters I've been using ONR on my cars. It works well, but I confess that I am attracted to this product's ease of use. Just spray it on and wipe off. I'm sure it would be much more economical to use ONR or Meguiar's new rinseless alternative, but given that I'm only washing my two personal cars, the cost is not a significant factor. I will definitely get a bottle once it appears at Advance Auto. The suggestion to visit the coin-op first is also a good suggestion. I do that sometimes before an ONR rinse, depending on how filthy the car is.
    --Al Kimel
  9. #39
    Registered Member ethereal45's Avatar
    May 2011
    Nebraska
    471
    Could someone explain the difference between a rinseless and a waterless wash?
  10. #40
    Jan 2010
    Pennsylvania
    16
    Quote Originally Posted by ethereal45 View Post
    A rinseless wash is when you add a product to a bucket of water and use that to clean your car. You dip your sponge or microfiber in the bucket and use that to remove dust and dirt from your vehicle and then dry. There is no rinsing with a hose involved like you would do in a traditional wash if you used car wash soap on your car hence the term rinseless wash. Optimum no rinse is a good example of that.
    A waterless wash is a product you spray on and wipe off to get the dirt off or your car. It doesn't require mixing it in a bucket of water. You just spray it on and wipe off the dirt with a microfiber towel.
  1. Trigger Wash aka Quik Detailer
    By Mike Phillips in forum Blast From The Past
    Last Post: Jul 10th, 2012, 02:41 AM
  2. which applicator for supreme shine trigger?
    By 79elcamino in forum Detailing 101
    Last Post: Apr 23rd, 2011, 06:52 PM
  3. Ultimate Protection Trigger vs. M40
    By roushstage2 in forum Meguiar's Consumer Line Products
    Last Post: Jan 31st, 2011, 11:05 AM
  4. Trigger Sprayer that won't Die from WB!
    By Andrew C. in forum Tricks of the Trade!
    Last Post: Aug 31st, 2010, 04:42 AM
  5. Trigger Sprayers
    By harshest in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Jun 4th, 2009, 05:27 PM
