DynaCone Pad Cleaner
  • DynaCone Pad Cleaner
    Product attributes:
    • Safe on the DynaCone and other metal polishing pads
    • Fast-acting surfactants dissolves away metal polishing grime
    • Replenishment for the cleaner in the Wheel Polishing Kit
    Part Number: G19410
    Size:
    10 ounce
    MSRP:
    $5.39
    This is the same cleaner included in our Wheel Polishing Kit - a fast-acting solution that dissolves metal polishing grime, leaving behind a like-new tool that is ready to detail at a moment's notice. This gentle formula can be used on any metal polishing or foam pad.
    To watch the dirt disappear, simply spray the product on the foam until it is thoroughly wet, and allow it soak in for a minute or so. Then dip the pad into warm water and watch the grime leave the foam pad as you squeeze the water out. Rinse the pad thoroughly with clear water before allowing to air dry.
    Re: DynaCone Pad Cleaner
    No love for this one?
    I have seen the pad cleaner in action and it is such an amazing pad cleaner.
    with its super deep cleaning power, can this product be used to deep clean foam pad that is caked with compound, polish and LSPs?
    I do have a few polishing pads that is caked with dirt...
    Dennis
    Nissan Fuga | 日產 風雅 | 日産 フーガ
      Yes, this is a great, great pad cleaner all around. We've had plenty of requests to release this as a stand alone, so here it is.
        So, just to make sure, this product can be use for ANY foam pad without side effect ? or try with my own risk
        because i read somewhere in this forum that this cleaner provide in wheel polishing kit is only for dyna cone ...
        thanks Mike
        so nice to have product that i can ask how exactly to use their product
        Meguiar all the way
        Proud to be part of Meguiars Family
          Yes, this product is safe to use on any foam pad. But keep in mind that the cleaning ability of the product is specifically designed to remove the black residue created when polishing bare metal. So, while it's safe for use on other pads, it may not necessarily be the most effective cleaner for what you're trying to get out of the pad. Make sense? You won't hurt anything, but you also may not get the exact result you're after, depending on what the pad was used for.
          And before anyone says "gee, didn't you test this on other stuff?" let's be clear here - this product was designed to fill a specific niche; the cleaning of an applicator that was used to polish bare metals. Whether you've used an old towel in the past for metal polishing, or another company's wheel polishing tool, you know all too well how dirty that job is and how difficult it is to clean the applicator/tool you used. This product addresses that and was originally packaged with the DynaCone in our Wheel Polishing Kit. If it does work on other things (and, yes, it very often does) then that's just a bonus for both you and us.
            Originally posted by sunexim
            It is seems to be good product but i had no reviews about this cleaner!
            Price are also affordable and i want to give it a try soon.
            If you want to see this cleaner in action check out the following threads:
            Wheel Polishing Kit
            Meguiar's Quik Tips Video Series - Quick and Easy Wheel Polishing We show the cleaning of the DynaCone with this product starting at about 1:40 in the video.
              Is this stuff available anywhere?
                I think this is only avail online....was looking around Walmart, etc....didn't see it.
                I'm wondering if Super degreaser or APC+ can clean the Dynacone well?
                "STRIFE" aka Phil
                  Does it come in a larger quantity?
                    For the time being, it only comes in the one size.
                      Hello Mr. Stoops,
                      May I ask if this product is discontinued?
                      Autogeek has this on back order.
                      Even Meguiarsdirect says "Sorry, this item is not available for purchase through MeguiarsDirect.com"
                      Any tips where I can find this will be great!
                      Dennis
                        Originally posted by PPLd View Post
                        Hello Mr. Stoops,
                        My guess is it has been discontinued. The Ollies Bargain stores around us had them in large amounts last fall @.99 ea.
                        See Kevin's '03 PT Cruiser GT here: http://www.cardomain.com/ride/477590
