Perfect Clarity Glass Cleaner
  • #31
    Re: Perfect Clarity Glass Cleaner
    Dear Jim
    Originally posted by jfelbab View Post
    FWIW, I find that UQW does a nice job of this. It is a great glass coating as it doesn't streak and sheds dust with just a wipe of a clean dry microfiber. It repels rain like RainX too but not for as long. It is much easier to apply and remove so I just use it after a wash on my paint glass and vinyl trim.
    Thank you very much. I'll give this a try.
    --Jaddie
    • #32
      Or UQD also.
      Just have to try a couple things, see what you are comfortable with.
      • #33
        Good catch about seeing it is ammonia free. Thanks Jaddie
        Vettefan
        • #34
          Loving that you guys are able to sort out some of these answers on your own with a little research and sharp eyes!!
          As for some window tint films turning purple and bubbling, it isn't always due to ammonia in the glass cleaner used on it - some films on the market are just really cheap and will do that after prolonged sun exposure, regardless what you do with them.
          • #35
            I am almost out of NXT Glass Cleaner.
            I will certainly buy a few bottles of this new glass cleaner in the Spring when I put my next stock order at ADS.
            • #36
              Thanks... and it seems to be on the cholos cars.....ARIBA!!!
              • #37
                How about a Meguiar's version of Rain-X, but in a one step clean & repel spray....for 2013
                "STRIFE" aka Phil
                • #38
                  Am I the only one that never uses a "window cleaner". I can't even remember the last time that I did. I might try this just for something to do.
                  • #39
                    Seriously?
                    How do you keep your windows clean?
                    • #40
                      At what temperature does Perfect Clarity start to freeze in the bottle?
                      David
                      • #41
                        I'm the same way too.
                        • #42
                          Between washes you've never cleaned your windows to remove bug splatter, road film, etc? I do this all the time, but then again I never use my car's windshield washers as it's impossible to not have that stuff running all over the place. My daily driver still has the factory fluid in the washer reservoir dating back to its build date of August, 2003. At least I think there's still some in there, unless it's all evaporated by now!!
                          It's not a high alcohol content product so you shouldn't let it sit in a car overnight if your anticipating freezing temperatures.
                          • #43
                            I clean windows as often as using detailer.
                            I like keeping glass cleaner in the car all the time along with the Ultimates (Wax and Detailer).
                            Thanks Mike for the info.
                            David
                            • #44
                              I found out that this new product will come out just few moments later after I ordered a bottle of NXT Glass Cleaner.. but once again.. I will get this one as soon as will come here in Italy. Just a couple of questions. It's written that will be dust repellent.. so should have some lubricants that stays in the glass and helps dust to slide but.. it will helps also water to slide more efficiently and even maybe helps the work of the wipers? Second question is.. why I should choose the aerosol version or the spray trigger version? Michael wrote about light foaming nature and clinging ability.. it's only preference in how to use the product or does it change something else?
                              • #45
                                Yeah, foam vs. trigger is just preference.
                                Trigger for me....
