Hot Rims All Wheel & Tire Cleaner
Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: Hot Rims All Wheel & Tire Cleaner
    21,405
    1140
    New & Improved
    Product attributes:
    • Reformulated to clean wheels and tires
    • Safe on all factory coated wheels
    • Visually see dirt leaving the wheel & tire
    • Increased foaming action
    All Wheel and Tire Cleaner is designed to wash away filth with ease, leaving behind not only clean wheels, but clean tire sidewalls as well. The Xtreme Cling solution foams and clings to the wheel and tire, turning from white to brown as it grabs all brake dust and grime. What's more, this unique product is safe to use on all factory coated wheels, taking the stress of finding the right wheel cleaner out of the equation.
    Part Number:
    G9524
    Size:
    24 ounce
    MSRP:
    $6.99
    Here are a few shots of the product in action:
    This tire and wheel don't look all that bad, right?
    This is the original Hot Rims All Wheel Cleaner sprayed onto half the tire/wheel combo.
    While the original formula dwells, the new version is sprayed on the other side. Same number of sprays with each product, same type of sprayer on the bottle, but you can see how much more foaming action there is with the new version, and how much more effectively it cleans the sidewall of the tire.
    After just several seconds of dwell time and all the crud is just running off the tire.
    Remember that this product must be rinsed off thoroughly with water and not simply allowed to self dry!
    Meguiars Indonesia Admin
    May 2011
    Jakarta, Indonesia
    136
    12
    Re: Hot Rims All Wheel & Tire Cleaner
    Nice bleeding ^^
    Registered Member ethereal45's Avatar
    May 2011
    Nebraska
    471
    15
    Wow that's pretty impressive. Will definitely give this a try over APC+.
    21,405
    1140
    This product has definitely been one of our favorite new product demos, that's for sure!
    May 2011
    Jakarta, Indonesia
    136
    12
    can't wait to see it with my own eyes ^^
    21,405
    1140
    Quote Originally Posted by PhantomMagician View Post
    We're working on getting a video up showing this very soon.
    Registered Member Teak's Avatar
    690
    24
    Looks good. So less tire scrubbing required. Does the rim still need to be agitated with brushes?
    Talk it over folks. Communication is the key.
    --Jerry Springer
    21,405
    1140
    Quote Originally Posted by Teak View Post
    Wheels may still need some agitation depending on amount of brake dust and whether or not you're using our new Hot Rims Brake Dust Barrier But the amount of crud removed from the tire even without agitation is pretty amazing. Still, in most cases some agitation is probably going to be called for.
    BMW Nut smack's Avatar
    May 2010
    Minot, ND
    966
    21
    Your kidding me. You scrubbed the right side of the tire after the application of the new stuff right? How about the wheels wells? Im sure it would work well on them right?
    2011 Jet Black 328i Touring
    2007 Jet Black 335i Sedan
    21,405
    1140
    Quote Originally Posted by smack View Post
    In the sequence of images shown in the original post we did nothing more than spray it on, let it dwell for a bit, then wiped off. That's it. As for its effectiveness on wheel wells, it should work very well but you might want to check that it doesn't cause an side effects on the plastic. We haven't checked to see if it might cause some staining or whitening of plastics like some cleaners can, so experiment at your own risk.
  1. Hot Rims all wheel cleaner on painted rims?
    By therdrman in forum Detailing 101
    Last Post: Oct 12th, 2010, 04:00 PM
  2. Replies: 4
    Last Post: Oct 21st, 2009, 06:18 PM
  3. Hot Rims All Wheel...ok for these rims?
    By 94SupraTT in forum Meguiar's Retail/Consumer Line Products
    Last Post: Sep 12th, 2009, 10:47 PM
  4. Hot Rims® All Wheel Cleaner
    By Speedway in forum Consumer Line - Product Reviews
    Last Post: Mar 4th, 2008, 06:49 PM
  5. Hot Rims All Wheel Cleaner
    By bill123 in forum Customer Service Hotline
    Last Post: Jul 13th, 2005, 05:22 AM
