Headlight Protectant
  • #16
    SRIFE,
    I'm going to assume this is like any other dressing/protectant. Meaning, you should remove the previous layer before applying a fresh one.
    • #17
      Re: Headlight Protectant
      do we need to wait for +- 30 to cure like we did when waxing ? or it just wipe on wipe off product ?
      Thanks
      Proud to be part of Meguiars Family
      • #18
        I really want to try this !
        Will it be in auto parts stores? Havent seen it yet in my area.
        • #19
          Originally posted by STRIFE View Post
          I'm dying to use my bottle....I recently used PlastX via DA....and protected the headlights with UQW.....do I need to remove the UQW before applying Headlight protectant? Or should I just apply on top of?
          UQW has some pretty tenacious polymers in it - you'd want it off before applying this so that it bonds properly
          Thanks
          As mentioned in another thread, application is similar to that of a pure polish rather than a traditional wax. That means wipe it on, work it in a bit, and wipe off right away.
          It should be in some of the major auto parts stores by now, even here in SoCal.
          • #20
            bookmark.
            • #21
              hey all,
              i've finally bought and used this product last weekend. I'm pretty satisfied with the results even on my 4 month old Elantra. the headlamps/tail lights look shiny from far. I do have an issue whereby there still seems to be some product leftover even after a thorough and hard wipe off with microfibers. its not obvious and you really need to scrutinize to see it, but its there. Could it be that i'm using more product than i really should? As I'm alternating UQD and UQW during my weekly washes, sometimes i do spray them on the headlights/tail lamps as well. Could this also coz the issue?
              • #22
                The Headlight Protectant is a fairly wipe on / wipe off product. If it dries, you may want a damp cloth to help remove.
                And same for the UQW, shouldnt be an issue, but if some residue was getting left behind, it could build up.
                • #23
                  Meguiar's Headlight Protectant should be applied by gently working the product into the headlight, and then wiping off immediately. Another option if the product does dry on the headlight is to simply re-apply and wipe off. We also recommend re-applying every 6-8 weeks to ensure even coverage.
                  • #24
                    How does this compare to just waxing them W/ nXt gen 2.0 wax ?
                    • #25
                      hey guys,
                      thanks for the advice. I did follow the instructions (wipe on, and wipe off immediately), but i think i used more product than necessary. also i think i was exerting quite a bit of pressure to spread the product. maybe that's my issue i'll try again in a month's time. overall i love it.
